enable buffer distance in buffer tool to be a parameter
1660
01-23-2018 05:02 AM
HazelAng2
Hi all,
I am trying to build a toolset for some users using the model builder but was stuck at the point where I want to enable users to set their own value for buffer distance.
The only parameters which i managed to create for the model are the input and output. Does anyone know if I am able to let the users set their own buffer distance as a parameter?
Thanks!
Tags (1)
DanPatterson_Retired
Just make it a parameter....  parameter in the model is designated with a ... P
arcmap and Pro both have them, see the picture and the procedure
http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/model-parameters.htm
JonasBjärnmark
Right click the buffer tool -> Create Variable -> From Paramameter. Try this for all the other tools you want to work with as well because it really simplifies the work flow! 🙂
