MaxRecordCount of layer
3375
6
01-21-2018 01:19 AM
LameesTaha
Now i have a feature layer with more than 1000 graphics and i don't want to change MaxRecordCount of layer and at the same time i need all graphics to be rendered on map ,, is there is away to do this without change MaxRecordCount of layer.
XanderBakker
Esri Esteemed Contributor
LameesTaha
i don't want to change maxRecordCount
XanderBakker
So, you want the functionality of what happens when you change maxRecordCount, but you don't want to change that setting. You could write your own renderer and when you consult the first 1000 features, detect if there are more and do additional requests to get the missing features, but it is really not the way I would recommend you to go if this can be solved by simply changing a setting on the service.
Surely you have a very good reason not to want to change the setting. Do you mind sharing this reason with us?
ChrisPedrezuela
possibly a cached service?
LameesTaha
i don't want to change maxRecordCount because it will affect performance and it's not recommended to do so
rest - Maximum number of record returned by the server. Why 1000? - Geographic Information Systems S...
i found a logic reply there
ChrisPedrezuela
keep 1000 record limit on the service but set an appropriate scale visibility setting (i.e. don't show layers when zoomed beyond 1:5000) on the layer to prevent it showing more than 1000 objects on a current map view.
