How can I represent water in CityEngine?
3520
01-19-2018 03:10 AM
PedroOliveira1
Is it possible to represent water in motion, a river for example?
Thank you
Pedro Oliveira
Luiz_AmadeuCoutinho
Hi Pedro
Yes you can. There´s two options:
1. Choose one polygon and add to the end of the name  " __water  " : example  myriver__water
A sample here http://bit.ly/2EWMpSR
2. Option two : Use the rule WaterMaterial.cga available on http://www.arcgis.com/home/item.html?id=067950a3a1f44129a10b3a458802e450
PedroOliveira1
Thank you, it worked.
greetings
RyanKocourek
Hi there,
Could you allow us access to download the cga file? It says that we don't have permission to access.
Thank you sir!
Luiz_AmadeuCoutinho
* File: WaterMaterial.cga
* Created: 30 May 2013 19:24:39 GMT
* Author: Craig
version "2013.1"
// A simple water texture rule with 5 different types - different colors, wave heights & speeds
@Order(1) @Range("River","Stream","Pond","Lake","Ocean")
attr Water_Type = "River"
@Range(0, 1.0)
@Order(2)
attr r = .44
@Range(0, 1.0)
@Order(3)
attr g = .55
@Range(0, 1.0)
@Order(4)
attr b = .44
@StartRule
Water -->
// __waterparams_scale_speed
case Water_Type == "River" :
set(material.name, "river__water__waterparams_5_10")
color(.44,.55,.44)
case Water_Type == "Stream" :
set(material.name, "river__water__waterparams_5_30")
color(.44,.55,.44)
case Water_Type == "Pond" :
set(material.name, "river__water__waterparams_1_3")
color(.2,.4,.45)
case Water_Type == "Lake" :
set(material.name, "river__water__waterparams_4_8")
color(.2,.4,.45)
case Water_Type == "Ocean" :
set(material.name, "river__water__waterparams_15_20")
color(.2,.4,.45)
else: X.
