Cannot add Attachment - Extension not Found
4952
01-19-2018 12:02 AM
MartinMaretta3
Hello we used Portal and Server version 10.3
When I try to add attachment to my feature service in Portal I have error message "Extension not found". When i check ArsGIS Server logs there is "Unable to process request. Extension not found".
My workflow is:
Publish map service with "Feature access" capability (has attachment is set to True)
I add this service as item to My Content to Portal
When i can edit data - add attachment  I have that error message "Extension not found".(I can see existing attachment)
When I open feature service in REST and open it in ArcGIS.com, I am able to add attachment.
Do you have any idea why i cannot add my attachment in Portal?
Is it even possible with federated service?
Could by problem with security? - certificate?
Thanks for response
Martin.
Tags (1)
PrashantKirpan
Recently had same issue when i tried to add attachment from browser.
I was using /featureserver/ in url and getting same error after adding attachment.
after changing /featureserver/ to  /FeatureServer/ attachments starts workng.
-Prashant
JonRaper2
Did you ever figure this issue out, I am getting same error, using the same workflow (Feature Service) but trying to sync edits back to server.
Jon
MartinMaretta3
Hi, Sorry I dont remeber.
We are already at 10.6.1 and havent this kind of issue
jorisfrenkel
Same problem here, but not with Portal but just a plain ArcGIS Server service published in AGOL. Version 10.6.1 and version 10.8.1. When adding the mapservice again, adding attachments works. Other editing operations work on the original, just not the attachments.
PrashantKirpan
-Prashant
