Least Cost Path unique shp origins/destinations
269
01-18-2018 06:49 AM
RobertoFilloramo
New Contributor III
Hi, everyboby,
I have several point in a unique shp file (I use arcmap), I would calculate the cost path (so the best rout according to the landscape surface) between all the same points each other. Is it possibile? How can I use the same shp as origins and destinations points? Or is it necessary to split the point in order to use them individually as origin while the unique shp as destination? thank you in advance for your time.
best regards
