| POST | Hi all, I'm new to GIS for archaeology. What are some of the major geoprocessing tools that you all like to use? I'm ... by ArchTim Emerging Contributor 0 0 | 0 | 0 | 899 | |
| POST | In COGO the Direction field can be displayed as DMS but when labelled how can the be replicated without writing a lot... by PaulPrevedoros1 Regular Contributor 0 0 | 0 | 0 | 975 | |
| POST | I'm currently work on a project that connects a data sheet of artifact data to sites (polygon and points) already in ... by Fitzpatrick_Natalie New Contributor 0 3 | 0 | 3 | 1849 | |
| POST | DBF file of atrtifactsPoint Files of precise sitesShape File of vague sites by Fitzpatrick_Natalie New Contributor 0 0 | 0 | 0 | 899 | |
| POST | Hi all,I've been trying to perform what seems like it should be a fairly simple task, but I've been unable to get it ... by TimDennehy Emerging Contributor 0 6 | 0 | 6 | 5552 | |
| POST | Has anybody attempted to quantify wetland data and soil data for rate of resistance to estimate least-cost pathways? ... by WillFeltz New Contributor 0 3 | 0 | 3 | 2222 | |
| POST | Hi there,I have two datasets. One is a point file of features, each with different size (area) values. The second is ... by HayleyGlover Emerging Contributor 0 2 | 0 | 2 | 1613 | |
| POST | 0 | 0 | 760 | ||
| POST | Hi all,I'm having a bit of trouble with something that i'm sure should be very simple.I have calculated the time cost... by netafriedman Emerging Contributor 0 0 | 0 | 0 | 823 | |
| POST | I have previously calculated the catchment areas for a series of archaeological sites. After making some minor adjust... by netafriedman Emerging Contributor 0 3 | 0 | 3 | 2093 | |
| POST | Hello,I have ArcGIS 10.3.1 and am trying to run a Least Cost Path analysis that incorporates Toblers hiking function;... by JustinMcKissick1 Emerging Contributor 0 0 | 0 | 0 | 798 | |
| POST | Hi, everyboby,I have several point in a unique shp file (I use arcmap), I would calculate the cost path (so the best ... by RobertoFilloramo Occasional Contributor 0 0 | 0 | 0 | 806 | |
| POST | Hi there,I am trying to generate a least cost path taking into consideration the energy (calories) expended crossing ... by PanosTzovaras Emerging Contributor 0 7 | 0 | 7 | 3636 | |
| POST | I can't find a good amount of information on creating a grid within a set boundary and using the intersection points ... by EricMai Emerging Contributor 0 26 | 0 | 26 | 12544 | |
| POST | I'm trying to predict in which areas there might be undiscovered archaeological sites but I cannot figure out how to ... by MadeleineNilsson1 New Contributor 0 2 | 0 | 2 | 1772 |
