repeat failing to populate feature service
860
01-16-2018 04:07 PM
danbecker
Portal for ArcGIS, publish from Desktop connect to the Portal, hosted feature service.
We have a repeat with this:
type: select_one species_domain
type: integer
end repeat
The species_domain has about 200 rows on the choices tab.
It seems like whatever I do, the survey never populates the in the hosted feature service. The records are there, but they're blank.
Anyone ever had this before?
danbecker
Here's the answer:
When publishing to Portal, all field names have to be lower, (I'm assuming this is because my db backend is PostGreSQL). When the field name is within a repeat, survey123 misses the field name check. When the field is moved outside the repeat, then you get the friendly reminder from survey123 when you try to publish.
UGH, learned something today.
JohnathanHasthorpe
Hi Dan
We will get this fixed, and ensure that Connect checks the fields inside of a repeat too.
Cheers
John
