add opacity range
2277
01-16-2018 11:21 PM
anjelinaponkerat
Hi
I have a tiled map service. I,m going to add opacity controller for this layer, but I can't!!
this is my code:
var housingLyr = new TileLayer({
  url: "http://localhost:6080/arcgis/rest/services/housing/MapServer",
  visible: false,
  opacity: 1
<body>
<span id="layerToggle">
  <input type="checkbox" id="housingLyr" />satellite layer
  <input id="opacity" type="range" min="0" max="1" step="0.1" value="1" />
</span>
Tags (1)
RobertScheitlin__GISP
Here is a sample:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Intro to MapView - Create a 2D map - 4.6</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
  <script src="https://js.arcgis.com/4.6/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/TileLayer",
      "dojo/on",
      "dojo/dom",
      "dojo/domReady!"
    ], function(Map, MapView, TileLayer, on, dom) {
      var map = new Map({
        basemap: "streets"
      var terrainLyr = new TileLayer({
        url: "https://services.arcgisonline.com/arcgis/rest/services/World_Terrain_Base/MapServer",
        visible: false,
        opacity: 1
      on(dom.byId('opacity'), "change", function(evt){
        terrainLyr.opacity = evt.target.value;
      on(dom.byId('terrainLyrCB'), "change", function(evt){
        terrainLyr.visible = evt.target.checked;
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 4,
        center: [15, 65] // longitude, latitude
      map.layers.add(terrainLyr);
  </script>
</head>
<body>
    <input type="checkbox" id="terrainLyrCB" />satellite layer
  </span>
  <div id="viewDiv"></div>
</body>
</html>
is this a 4.x or 3.x question? You need to add Tags to your posts with this info. Also since you ask so many questions you need to learn how to properly post code using the advanced editor and Javascript syntax highlighting.
Updated Content Text Editor
anjelinaponkerat
Here is a sample:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/on",
      "dojo/dom",
      "dojo/domReady!"
      var map = new Map({
        basemap: "streets"
        visible: false,
        opacity: 1
        map: map,
        zoom: 4,
  </script>
</head>
<body>
  </span>
</body>
</html>
