how to change zoom feature length in address search
2852
10
01-17-2018 09:49 AM
devarsimajumder2
rscheitlin
we are trying to see if there is  a  way we  can set the length of zoom  the  address search does  when we look for a  address. Instead of going right to the address, is there a way we can change the zoom in length it goes?
RobertScheitlin__GISP
Devarsi,
  When you are asking questions make sure you choose to start a new Question and not a new Discussion.
This question has been asked and answered a few times already. Her is one such thread:
https://community.esri.com/thread/175998
devarsimajumder2
On the json file, which one do we use. I opened the one that is under the widgets file called search, but I don’t see the lines where it needs to be place.. I have attached a pic. I am using the right one
Devarsi,
  No once a widget has been configured for an app the proper location for config changes is in the apps configs folder (i.e. [instal dir]\server\apps\[app#]\configs\Search\config_Search.json)
devarsimajumder2
Ok I have found the file that you are talking about. What code do I put in here to change the zoom file. I have attached a pic to show how the coding looks so far.
Devarsi,
   You need to re-read the thread I posted earlier. The fix I suggest has nothing to do with the json file.
devarsimajumder2
I read the thread and I saw that any changes are made in the config folder. What I am not understanding is how to change it. That is what I need help with.
I went to that folder and accessed the config file. The concern I have is where I put the code that you wrote out in the thread where its marked correct answer.
Devarsi,
   The reply that was marked the correct answer in that thread was for minified code in the Widget.js (which is what the original poster needed). In your case you need to use the first response I made to the Original poster (many times you need to read the whole thread to understand).
devarsimajumder2
I have read the thread but I am sorry maybe im not understanding where you made the orginal post or what but this is very confusing for me. Im still new to javascript programming if you can please help me out or show me where in the thread which lines to use I would appreciate it.
Thank you
