Displaying spatial coordinates from SQL database
1562
01-12-2018 09:22 AM
MathewMullan1
I have a SQL database with spatial coordinates that I want to display in a Map View hosted in a web application. I have the Map View already rendered but I need some direction on where to start with getting the data displayed on the map.
RobertScheitlin__GISP
Mathew,
   You will need a web service to query and return the data in Json format. If you have some .Net development skills then a simple Google for Creating a RESTfull web service in .Net will do.
MathewMullan1
Hi Robert,
Thank you for the feedback. I am able to return the data with ease but I'm unfamiliar with how to get the actual points on the map using the javascript.
OK, That is the easy part.
you create point using the Point class and the coordinate you returned from SQL database.
https://developers.arcgis.com/javascript/3/jsapi/point-amd.html#constructors
And a simple marker symbol
https://developers.arcgis.com/javascript/3/jsapi/simplemarkersymbol-amd.html#constructors
Then create a graphic from the above two
https://developers.arcgis.com/javascript/3/jsapi/graphic-amd.html#constructors
and add that to the maps graphics layer
https://developers.arcgis.com/javascript/3/jsapi/map-amd.html#graphics
Refer to this sample for more specific code:
https://developers.arcgis.com/javascript/3/jssamples/graphics_create_circles.html
ThomasColson
The easiest way to do this without a lot of custom code on your front end (which will have to change everytime there's a backend change)...would be to add a trigger to pull the coordinates out of the geography (or geometry) object. This gives you a permanently populated and updated XY field.
CREATE TRIGGER [dbo].[tigger]
ON [dbo].[feature class]
after INSERT,UPDATE NOT FOR REPLICATION
AS
BEGIN
 SET NOCOUNT ON;
 UPDATE p SET
 SHAPE = CASE WHEN i.SHAPE IS NOT NULL
 THEN p.SHAPE ELSE Geography::STPointFromText('POINT('
 + CAST(p.LON AS VARCHAR(20)) + ' '
 + CAST(p.LAT AS VARCHAR(20)) + ')', 4269) END,
 LON = CASE WHEN p.SHAPE IS NULL THEN p.LON ELSE p.SHAPE.Long END,
 LAT = CASE WHEN p.SHAPE IS NULL THEN p.LAT ELSE p.SHAPE.Lat END
 FROM feature class
 AS p
INNER JOIN
 inserted AS i
 ON i.globalid = p.globalid
END
