Going from ArcGIS API for JS to WAB
6086
15
01-11-2018 08:38 AM
AbhinavSharma
Hey guys, I was wondering if there is any documentation available (if it is even possible) about converting a webmap from the javascript api into a widget/webmap on the web app builder.
As an example I am attempting to create an application where the user can edit features without a popup of any sort appearing. I understand that there is a code sample that does exactly that and i have linked it below. But I am using agol and do not host anything on my own servers, so i need this functionality in the form of a widget.
Linked js example : Edit without editor widget | ArcGIS API for JavaScript 3.23
Tags (1)
Juan_ManuelAngel
Hi Ab i get this solution.
This is what you want ?
Firts You need to develope the Widget folder, its look like this, then you need to create your html and your java script code. i am going to attach the code of the widget, you know how to add the widget to the web app builder widget pool?
Juan_ManuelAngel
Try To search in this SDK Get started—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers  and in my opinion just delete all the creation of the web map in the widget and use the expretion "this.map", look this example from Route Example:
define([
'dojo/_base/declare',
'jimu/BaseWidget',
'jimu/loaderplugins/jquery-loader!https://code.jquery.com/jquery-git1.min.js',
"dojo/dom",
"dojo/_base/array",
"esri/urlUtils",
"esri/map",
"esri/graphic",
"esri/tasks/RouteTask",
"esri/tasks/RouteParameters",
"esri/tasks/FeatureSet",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"dojo/on",
"dijit/registry",
"dijit/layout/ContentPane",
"dijit/form/HorizontalSlider",
"dijit/form/HorizontalRuleLabels",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
function(declare, BaseWidget, $,dom,array,urlUtils, Map, Graphic, RouteTask, RouteParameters,
FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol) {
//To create a widget, you need to derive from BaseWidget.
return declare([BaseWidget], {
// DemoWidget code goes here
//please note that this property is be set by the framework when widget is loaded.
//templateString: template,
baseClass: 'jimu-widget-demo',
postCreate: function() {
this.inherited(arguments);
console.log('postCreate');
startup: function() {
console.log('startup');
//VARIABLES !!
var mapc,routeTask, routeParams,route;
var stopSymbol, routeSymbol, lastStop;
var map = this.map;
var mapc = this.map;
AbhinavSharma
So in the widget just have actions and any reference I make to the map or layers of the map can be done using "this.map", and using my above example I should just start from the "function initEditing(evt) {" line and work my way down from there.
Juan_ManuelAngel
yeah thats right, and in the event call the map and try to define the modules from the basewidget.
AbhinavSharma
after copying the code from This Code sample and attempting to convert the code to Web App builder my widget refuses to load. I get a pop-up that says " Create widget error" and in the console i am getting "Error: uniqName_8 template:config.configText"
I also do not see how I can add the html to widget.js. I have attached my widget.js code below:
define(['dojo/_base/declare',
'jimu/BaseWidget',"esri/map",
"esri/toolbars/draw",
"esri/toolbars/edit",
"esri/graphic",
"esri/config",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol",
"esri/dijit/editing/TemplatePicker",
"dojo/_base/array",
"dojo/_base/lang",
"dojo/parser",
"dijit/registry",
"dijit/form/Button",
"dojo/domReady!"],
function(declare, BaseWidget, map, draw, edit, graphic, config,FeatureLayer, SimpleMarkerSymbol,SimpleLineSymbol,SimpleFillSymbol,
TemplatePicker,array,lang,parser,registry,BorderContainer,ContentPane,Button,domReady) {
baseClass: 'jimu-widget-ROP',
this.mapIdNode.innerHTML = 'map id:' + this.map.id;
require(["jimu/LayerNode"], function(LayerNode) { /* code goes here */ });
var map = this.map;
_initEditing: function(evt){
console.log("InitEditing",evt);
var currentLayer = null;
var layers = arrayUtils.map(evt.layers, function(result){
return result.layer;
console.log("layers", layers);
var editToolbar = new Edit(this.map);
editToolbar.on("deactivate", function(evt){
currentLayer.applyEdits(null,[evt.graphic], null);
arrayUtils.forEach(layers,function(layer){
var editingEnabled = false;
layer.on("dbl-click",function(evt){
event.stop(evt);
if (editingEnabled == false){
editingEnabled = true;
editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
else{
currentLayer = this;
editToolbar.deactivate();
var templatePicker = new TemplatePicker({
FeatureLayer: layers,
rows: "auto",
columns: 2,
grouping: true,
style: "height: auto; overflow: auto;"
}, "templatePickerDiv");
templatePicker.startup();
var drawtoolbar = new Draw(this.map);
var selectedTemplate;
templatePicker.on ("Selection-Change", function(){
if (templatePicker.getSelected()){
selectedTemplate = templatePicker.getSelected();
switch (selectedTemplate.featureLayer.geometryType) {
case "esriGeometryPoint":
drawToolbar.activate(Draw.POINT);
break;
case "esriGeometryPolyline":
drawToolbar.activate(Draw.POLYLINE);
break;
case "esriGeometryPolygon":
drawToolbar.activate(Draw.POLYGON);
break;
drawToolbar.on("draw-end", function(evt){
drawToolbar.deactivate();
var newAttributes = lang.mixin({}, selectedTemplate.template
.prototype.attributes);
var newGraphic = new Graphic(evt.geometry, null, newAttributes);
selectedTemplate.featureLayer.applyEdits([newGraphic],null,null);
KenBuja
MVP Esteemed Contributor
The first thing to make sure the modules you're calling in "define" are in the same order as the arguments you're assigning them in "function". They are all messed up in your code.
AbhinavSharma
Well that's embarrassing, I went ahead and changed it and am still getting the same error message after refreshing the page.
Juan_ManuelAngel
Can you explain what widget do you want to create ?
AbhinavSharma
For now I just want to re-create  this sample (but using my layer) so i can learn how to properly develop in WAB. I have fixed the errors I mentioned above but am now getting a reference error. in the startup command." ReferenceError: initEditing is not defined"  Ill post my code below.
"esri/graphic",
"esri/config",
"dojo/_base/array",
"dojo/_base/lang",
"dojo/parser",
"dijit/registry",
"dojo/domReady!"],
function(declare, BaseWidget, map, draw, edit, graphic, esriConfig, FeatureLayer, SimpleMarkerSymbol,SimpleLineSymbol,SimpleFillSymbol,
TemplatePicker, arrayUtils, lang, parser, registry, BorderContainer, ContentPane, button, dom) {
parser.parse();
var map = this.map;
this.map.on("layers=add-result", initEditing);
initEditing: function() {
console.log("initEditing",evt);
event.stop(evt);
else{
rows: "auto",
columns: 2,
grouping: true,
break;
break;
break;
KenBuja
I'm seeing a typo here:
this.map.on("layers=add-result", initEditing);‍‍
that should be
this.map.on("layers-add-result", initEditing);‍‍‍
Also, this line won't work properly, since the events are case-sensitive
It would be helpful if you used Syntax Highlighting when posting code, since that would let us point to specific line numbers and make it easier to read
