Error When Trying To Collect Data Using Collector
1485
01-11-2018 07:52 AM
JohnSmith40
I set up a Collector app to collect utility features. However, when I attempt to capture a GPS point I get the following error:
"Update Failed. Updates could not be sent. Unable to complete operation. Geometry could not be set."
The features I am trying to collect are in a geometric network. Is it possible to collect GPS points in a feature class that uses a geometric network?
Thank you for your time and help.
Kylie
by Esri Regular Contributor
Hi John -- Collector can edit features that are in a geometric network, but there are some limitations:
  • You need to use ArcGIS Server 10.3.1 or later.
  • If you're working offline, you need to use a geodatabase at version 10.2 or later.
  • You need to use versioned data for editing.
Also a word of caution: Collector treats all the feature services as simple feature services, and the restrictions of the geometric network are ignored.
Supported data—Collector for ArcGIS | ArcGIS
Esri Education Team
JohnSmith40
Thank you for the information
