Utilizing ArcGIS Arcade with the Search Widget
1240
01-08-2018 09:03 AM
CraigPrisland2
Hi all,
I interested in seeing if anyone has run into this issue yet.
I am using ArcGIS Arcade in my popups in WAB 2.6 dev editon.  When I use the Search widget to search for a particular feature, the Arcade expression is not visible in my popup in the found feature (I have the 'Show pop-up for the found feature or location' option checked in the Search widget config).  However, I can click on the same feature again and then the Arcade expression appears.  Has anyone else experienced this and if so, how did you get around it?
Thanks in advance,
Craig
RobertScheitlin__GISP
Craig,
   No that seems like a bug in the search widgets implementation of the features popup. You will need to call tech support to log a bug for this.
LeonS
Yes, I have run into the same behavior using WAB 2.6.  I have scrapped Arcade in my pop-up for now because of this.  Not exactly a work around
CraigPrisland2
Thanks guys.  I'll get in contact with tech support on this issue.
Craig
