ArcOnline Hosted Feature Service attributes null after sync in ArcMap
1661
01-08-2018 12:11 PM
TimS
After adding my hosted feature service to ArcMap from ArcOnline and creating a local copy for editing, creating a feature, and syncing my edits with server, my points, lines, polygons remain but the information entered in my attribute table disappears and turns to <null>.
This appears to really only be affecting a text column I have called "Type" which was created to match symbols to a style in ArcMap.  For example, one line feature for "Transfer Piping" could be symbolized with different colors for different types of piping.  Other columns such as a text column called "Comments" does not have this issue after Sync.
Any help would be greatly appreciated.
Tim
by Anonymous User
Not applicable
So, for clarity, you published directly to ArcGIS Online from ArcMap a hosted feature layer.
You then pulled a replica from AGOL to do some editing in ArcMap.
Then, when you went to sync your edits, your 'Type' field got nulled out.
Is my understanding correct?
shan_sarkar
Tim,
Do you have any other text field where the issue?
Type is a reserved keyword for ArcGIS, if it is possible try to rename the field and see if it works out.
I hope this helps!
~Shan
~Shan
