Setting Map Extent Based on Layer Extent
6096
10
01-04-2018 12:04 PM
deleted-user-1_r2dgYuILKY
I want to set my map's extent to the extent of a feature layer. This layer will be updated regularly and the extent will be different every time. I'm following this example, and substituted my layer. It's not showing up, and the extent is far to the north of my feature. I'm getting this error in the console: Map: Geometry (wkid: 3395) cannot be converted to spatial reference of the map (wkid: 102100). I've tried setting the spatial reference of the map and the layer, to no avail.
<html>
<head>
  <title>Resource Loader Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.23/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.23/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.23/"></script>
  <script>
    require([
      "esri/map",
      "esri/layers/FeatureLayer",
      "esri/geometry/Extent",
      "esri/SpatialReference",
      "dojo/on",
      "dojo/domReady!"
      function (Map, FeatureLayer, Extent, SpatialReference, on) {
       var typhoonOutlineURL = "http://<ourserver>/arcgis/rest/services/typhoon_outlines/MapServer/0";
        var myLyr = new FeatureLayer(typhoonOutlineURL, {
          mode: FeatureLayer.MODE_ONDEMAND,
        myLyr.on('load', initMap);
        function initMap() {
          var mapMain = new Map("mapDiv", {
            basemap: "dark-gray",
            extent: myLyr.fullExtent,
            zoom: 3
          mapMain.addLayer(myLyr);
  </script>
</head>
<body class="claro">
  <div id="mapDiv" style="width:900px; height:600px;"></div>
  <div id="mapInfo"></div>
</body>
</html>  ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Levi,
   Here is the Sample again using a different map service layer and it still works for me:
<html>
<head>
  <script>
    require([
        "esri/map",
        "esri/tasks/query",
        "dojo/on",
        "dojo/domReady!"
      function(Map, FeatureLayer, Extent, SpatialReference, Query, on) {
        var typhoonOutlineURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/MtBaldy_BaseMap/MapServer/0";
          var query = new Query();
          query.where = "1=1";
          query.outSpatialReference = new SpatialReference(102100);
          myLyr.queryExtent(query, function(result){
              extent: result.extent
  </script>
</head>
  <div id="mapDiv" style="width:100%; height:100%;"></div>
</body>
</html>
Levi,
   The maps extent will only take a WGS84 or WebMercator extent if you are using an esri basemap (thus the warning). You can use queryExtent to get the layers extent in 102100 though:
<html>
<head>
  <script>
    require([
        "esri/map",
        "esri/tasks/query",
        "dojo/on",
        "dojo/domReady!"
        var typhoonOutlineURL = "http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Water_Network/MapServer/20";
          minScale: 0
  </script>
</head>
</body>
</html>
OK, this works, but the layer is still not visible. I can also just change the projection to web mercator before I publish, no?
Levi,
No that layer had a min scale so I have updated the code to override the minScale.
I did the same with my layer and still can't see it.
Strange. What is the layer minScale and maxScale in the Rest directory?
It was set before publishing to show at all scale levels, so there isn't a min or max scale. There is just an extent
Extent:
      XMin: 5029414.594027907
      YMin: -3514203.489426465
      XMax: 6130364.357942293
      YMax: -1622093.9552736997
      Spatial Reference: 3395  (3395)
Then that is not the issue... Hmm
EvelynHernandez
What u cannot see? i see this:
Levi,
<html>
<head>
  <script>
    require([
        "esri/map",
        "esri/tasks/query",
        "dojo/on",
        "dojo/domReady!"
  </script>
</head>
</body>
</html>
