How to Add Animation / Smooth Pan On Setting New Center For Map
2173
01-04-2018 07:56 AM
BehrouzHosseini
Can you please take a look at this demo and let me know how I can add smooth animation or Pan function to move to the destination?
As you can see I am trying to re-center the map center by
 map.centerAt(new Point(-78.542, 37.61, new SpatialReference({wkid: 4326})));
on a click event but this is jumping the map to the destination.
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
    <link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css" integrity="sha384-BVYiiSIFeK1dGmJRAkycuHAHRg32OmUcww7on3RYdg4Va+PmSTsz/K68vbdEjh4u" crossorigin="anonymous">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
    <script src="https://js.arcgis.com/3.23/"></script>
    <script>
      var map;
      require(["esri/map", "esri/geometry/Point","esri/SpatialReference","dojo/domReady!"], function(Map, Point, SpatialReference) {
        map = new Map("map", {
          basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13
        $(".btn").on("click", function(){
    </script>
  </head>
  <body>
     <button type="button" class="btn btn-default">Go There</button>
    <div id="map"></div>
  </body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Bengi,
Here is a sample that sets the APIs default animation.
<!DOCTYPE html>
<html>
  <head>
    <title>Customize Map Navigation Animation</title>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script>
      var map;
      require(["esri/map", "esri/geometry/Point", "esri/SpatialReference", "esri/config", "dojo/domReady!"], function(Map, Point, SpatialReference, esriConfig) {
        //configure map animation to be faster
        esriConfig.defaults.map.panDuration = 500; // time in milliseconds, default panDuration: 350
        esriConfig.defaults.map.panRate = 50; // default panRate: 25
        esriConfig.defaults.map.zoomDuration = 500; // default zoomDuration: 500
        esriConfig.defaults.map.zoomRate = 1; // default zoomRate: 25
          basemap: "satellite",
          center: [-93.5, 36.972],
          zoom: 5
        setTimeout(function(){
        }, 1000)
    </script>
  </head>
  <body>
  </body>
</html>
BehrouzHosseini
Thanks Robert but this is working fine on only Zoomed out maps. I tried to use a zoom level of 12 or 14 and jumping was happening again
Bengi,
  You just need to play with the panDurration and panRate numbers then until your happy.
