Layer doesn't show up when using Chrome browser
2007
12-29-2017 12:14 AM
WoraminSattayatharn1
Hi there
Currently, I'm creating a web application for user and ran into a strange problem.
My team published this map services to show the symbol of EVStation. (Url below)
https://gisadaptor.mea.or.th/mapstd/rest/services/ev/evRequest_pdt/MapServer/0
The problem is this map service wasn't load when one of my tester open this website with Chrome browser. However, other tester can open the website and the map service was loaded without any problem.
Further, when I tried debugging it and open the console developer of Chrome browser, somehow map service was correctly loaded. But when I closed the console developers, the problem came back and map service wasn't loaded
Curiously, this happened with only one tester. Other testers who also used the same version of Chrome browser didn't run into this problem. Is there anyone used to run into this problem can you help me specify what's going on here? Any help will be very appreciated
By the way, if you want to try the application. Here's the link
https://developers.geotalent.co.th/meaev/Index.aspx#/planning
(It is required to login, so here is username and password
Username : meastaff2
Password : abc123)
Thanks for your help
Woramin
EvelynHernandez
That is what i see.
This is my g.chrome ver:
RobertScheitlin__GISP
Woramin,
  Does the one machine that is having issue show anything useful in the browser web console, as far as errors? I tested your app using the latest Chrome and do not have any issue seeing the layer.
