Responsive apps using CSS Sample
2273
5
12-27-2017 01:27 PM
deleted-user-OlpHy1NoMNug
Having trouble getting one of the latest samples in the JS API to work, Responsive apps using CSS | ArcGIS API for JavaScript 4.6
Everything works if I open it on a desktop and then shrink the window down but if I open it on mobile or even simulate mobile with the dev tools it doesn't seem to honor the breakpoint.  Any ideas?
Tags (3)
RobertScheitlin__GISP
Scott,
  The difference I see is that the sample checks the apps size at load:
      // Load
      isResponsiveSize = view.widthBreakpoint === "xsmall";
      updateView(isResponsiveSize);
and you are just assuming that the app is at a desktop break point by doing:
// Add items to user interface
view.ui.add(anchor, "bottom-left");
view.ui.add(searchWidget, "top-right");
view.ui.add(locateBtn, "top-left");
view.ui.add(legend, "bottom-right");
You need to use the Advanced editor and the "Syntax Highlighter" when pasting code.
Scott,
  Strange, I can not duplicate what you are seeing using the latest version of chrome and the sample live site (not the sandbox).
https://developers.arcgis.com/javascript/latest/sample-code/view-breakpoints-css/live/index.html
Yeah you're right.  Must be something odd in my code.  Here's what I have.
// Desktop
var legend = new Legend({
view: view,
container: document.createElement("div")
// Mobile
var expandLegend = new Expand({
view: view,
content: new Legend({
view: view,
//Map Constraints
view.constraints = {
rotationEnabled: false
// Breakpoints
view.watch("widthBreakpoint", function(breakpoint) {
switch (breakpoint) {
case "xsmall":
updateView(true);
break;
case "small":
case "medium":
case "large":
case "xlarge":
updateView(false);
break;
default:
function updateView(isMobile) {
setLegendMobile(isMobile);
function setLegendMobile(isMobile) {
var toAdd = isMobile ? expandLegend : legend;
var toRemove = isMobile ? legend : expandLegend;
view.ui.remove(toRemove);
view.ui.add(toAdd, "bottom-right");
Sorry the formatting is so bad on that.  I looked at previous posts which said to just copy and paste but that didn't seem to work.
Scott,
      // Load
Perfect.  Not sure how I missed that, thanks.
Updated code:
// Desktop
    view: view,
  // Mobile
    view: view,
      view: view,
  // Load
  // Breakpoints
      case "xsmall":
        updateView(true);
        break;
      case "small":
      case "medium":
      case "large":
      case "xlarge":
        updateView(false);
        break;
      default:
