How do I view what Inlets I have inspected using the built in related "Inspections" table.
421
12-30-2017 08:36 AM
AshlieHildebrand
I'm using the ESRI Stormwater Solutions in ArcGIS Online. If I use the built in "Inspections" function to inspect all my Stormwater Inlets, how do I then view on a map which Inlets I have inspected? Or which inlets are going to require work later. That would be very useful when my guys are out in the field doing inspections. I don't see that functionality as is...do I need to add a field in the "Inlets" layer that says "Inspected" Yes or No, and "Follow up Required" Yes or No to be able to make those inlets a different color once they are inspected.....?
