select_multiple_external?
1279
12-29-2017 11:03 AM
DanielKonzek
Can an external choices list be used for a select_multiple question?  My form works if this question is a select_one, but I get an error that says "Unknow question type' when I change the question to a select_multiple.
Thank you!
JohnathanHasthorpe
Hi Dan
External selects are only designed to work with choice lists associated with a cascading select, and therefore only work with a select_one question type.
John
GISAdmin23
Johnathan Hasthorpe‌ has the S123 team considered supporting external selects for select_multiple question types? This would be a beneficial addition for not only our organization but I could see other orgs benefiting from it as well.
JamesTedrick
Esri Esteemed Contributor
Supporting cascading (and external) selects for select_multiple is an enhancement that has been raised by a number of customers; it is logged in Esri Support as ENH-000103222 if you would like to be attached to it.  At this time, there is not a definite timeline for bringing this feature into the application.
