Map widget in ArcGIS API for Python 1.3 not working?
1911
12-19-2017 12:33 PM
Ericvan_Rees
I installed the latest version of ArcGIS API for Python (v 1.3.) today on Windows 10 through conda in a separate virtualenv. The map widget is not displaying, although I can run commands such as map.center and get coordinate data returned. I get no error messages or whatsoever, everything seems be installed correctly. What could be the problem here?
#arcgis api for python‌ python 3.6
OSINT_ENGINEER
Any progress on this? Same issue using a clean conda installation and the current arcgis release. Any Ipython widget version conflict?
RohitSingh2
The current conda install lays down ipywidgets v7.0, which is incompatible with the map widget in ArcGIS API for Python v1.4.0
A workaround is to `conda uninstall ipywidgets` and then `conda install -c esri arcgis`. Alternatively, you can create a new conda environment, activate it, and install the ArcGIS API for Python in the new environment, and then the map widget should work.
We are working on updating the widget to work with the latest version of ipywidget.
JohnYaist1
Hey Eric van Rees
Check out the System Requirements page - map widget issues typically occur when the ipywidgets and/or widgetsnbextension packages are not at the right release. If the versions are in the correct range, try running this before opening the notebook:
jupyter nbextension enable --py --sys-prefix arcgis
