Event listener on popup open?
11427
12-20-2017 02:33 AM
LarsFagerbakke
Is there a way to add an event on a popup open event? I want, based on its target, to perform a AJAX call and retrieve more data to populate the content field from a third party system.
Popup only has the "trigger-action" event that handles action within the popup.
Tags (1)
RobertScheitlin__GISP
Lars,
   There are actually very few events in the 4.x api. You now just watch properties.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Popup.html#visible
Use view.popup.watch("visible", function(){});
RyanBohan
Thank you Robert, this is what I was looking for.
I was getting doubled results when the pop up was turned on and off, so I added an if statement
view.popup.watch("visible", function (popUpStatusChange) {
   if (popUpStatusChange == true) {
     console.log("Pop-up watch has been fired")
     console.log("Pop-up title is:", view.popup.title); //returns the pop up title
     console.log("Pop-up content is:", view.popup.content); //returns the pop up content
zhongrenGu
