Data tables not loading in arcgis online webapp
3021
5
12-18-2017 07:43 AM
CurtPope
I have a webapp that has been working for a few years. Recently I am unable to get the data table widget to load the data.  And i can't diagnose the problem.  I can see the tables just fine in the web map that the App was created from but i am at a loss as to why they are not carrying over
RobertScheitlin__GISP
Curt,
   Have you checked for errors listed in the browsers web console?
CurtPope
Thanks for mentioning that i had not thought to look there. It seems the table widget is trying to hit an old unsecured IP address. So now the question becomes how do i get it to hit the correct HTTPS address for the data
Curt,
   Make sure that the web map is using https urls on all the data it contains.
CurtPope
Everything seems to be points to the HTTPS urls the data table is the only thing that isn't working correctly and on further research it is only some of the data that isn't loading. 3 of the services are just fine.
Curt,
   Could be that your Service is just having an issue and you need to restart that service on your ArcGIS Server.
