map zoom level when clicking on item list
22285
29
12-15-2017 11:38 AM
MikeOnzay
Is it possible to set the map to zoom to a particular level when clicking on an item in a list?
by Anonymous User
Not applicable
For polylines and polygons, the app zooms to the extent of the feature.
For points, there is a "pointZoomScale" property that can be added/modified in the dashboard json (via AGO Assistant or other) to set a specific zoom scale. This property is not exposed to the dashboard creator at this time and must be manually changed in the json.
The app currently defaults to 10,000. So setting this property to a value like 1,000 will allow the map to zoom in more. The setting is per-webmap.
pointZoomScale
by Anonymous User
Not applicable
pointZoomScale
BrendanBladdickEsri
Make sure to have the correct capitalization or it will not respect the parameter:
"pointZoomScale"
Lake_Worth_BeachAdmin
thanks this worked, however my JSON did not have this parameter to begin with, I had to add it.
BrendanBladdickEsri
Correct, this is a parameter that we had to add to this JSON, it was not already there.
PaulCone2
I want to zoom to a polygon (buildings) and show some of the surrounding area for context.  Is there a polygonZoomScale property too?  I tried it but nothing happened.
Paul
WilliamTrachtman
I have the same issue as well.  The zoom to polygons is not very good.  Is there a setting that can be changed for polygons? Aaron Pulver
PhilipShutler
Did anyone ever provide a solution to change the zoom to extent for polygons?
MattWilkie3
How do you get to the dashboard json in order to modify this parameter?
Kanin
by Esri Contributor
Hello Matt,
You can use ArcGIS Online Assistant to get the Dashboard's JSON. However, please be careful when editing the JSON configurations as it could cause errors with the Dashboard. It is recommended to save a copy of the Dashboard, rather than editing the actual Dashboard.
Best,
Kanin
