Apparent reflectance for WV-3 imagery?
492
12-15-2017 12:57 PM
MorganBond
I would like to use the Apparent Reflectance Function with some Worldview-3 multiband imagery. However, the appropriate corrections do not populate from the metadata that is supplied by Digital Globe. I know there are a number of patches out there for desktop 10.3 with respect to the Worldview-3 imagery. Does anyone know if any of those patches resolve this issue, or if there are plans in place to make that function work with this imagery?
George_Thompson
Esri Frequent Contributor
Here is the Worldview patch: Esri Support 10.3 (10.3.1)
You can also search for patches at a certain version of the software here: Esri Support Downloads
That is how I found the patch above. Hope this helps.
--- George T.
MorganBond
I have installed this patch, but it does not do anything to help populate the information needed to calculate apparent reflectance. I am not sure if this is a problem with the apparent reflectance function or the way the VW-3 data are interpreted but it still does not work.
