FeatureTables name related records fields
1858
7
12-13-2017 01:39 AM
MaximSpikin1
in ESRI sample FeatureTable - related records | ArcGIS API for JavaScript 3.22  field  "groupBySummary"
That name for this field?
How can i format it in "fieldInfos" or hide in "HiddenFields" properties?
for example, that I should write in the parameter "name" and so on.
fieldInfos: [
      name: 'groupBySummary',  - ???????????
      alias: 'groupBySummary_alias',
Thanks.
RobertScheitlin__GISP
Maxim,
  OK,
  here is the code for that:
          myFeatureTable.on("load", function(evt){
            //toggle the 9 column to hidden
            myFeatureTable.grid.toggleColumnHiddenState(9, true);
            var rFldTtile = dojoQuery(".esri-feature-table-column-header-title.esri-feature-table-related-records-title").forEach(function(item, index){
              item.innerHTML = "Relate " + index.toString();
Maxim,
  Here is a sample on how to change the column name for the relates and attachments column:
<!DOCTYPE html>
<html>
<head>
  <title>FeatureTable - related records</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
  <script src="https://js.arcgis.com/3.22/"></script>
  <style>
    html, body, #map{
      width:100%;
      height:100%;
      margin:0;
      padding:0;
  </style>
 <script>
    require([
      "esri/layers/FeatureLayer",
      "esri/dijit/FeatureTable",
      "esri/tasks/query",
      "esri/geometry/Extent",
      "esri/symbols/SimpleFillSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/Color",
      "esri/map",
      "esri/dijit/Popup",
      "esri/dijit/PopupTemplate",
      "dojo/dom-construct",
      "dojo/dom",
      "dojo/number",
      "dojo/parser",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dijit/registry",
      "dijit/form/Button",
      "dijit/layout/ContentPane",
      "dijit/layout/BorderContainer",
      "dijit/form/TextBox",
      "dojo/query"
    ], function (
      FeatureLayer, FeatureTable, Query, Extent, SimpleFillSymbol, SimpleLineSymbol, Color, Map,
      Popup, PopupTemplate, domConstruct, dom, dojoNum, parser, ready, on,lang,
      registry, Button, ContentPane, BorderContainer, TextBox, dojoQuery
      parser.parse();
      ready(function(){
        var popupOptions = {
          marginLeft: "20",
          marginTop: "20"
        // create a popup to replace the map's info window
        var popup = new Popup(popupOptions, domConstruct.create("div"));
        var map = new Map("map",{
          basemap: "topo",
          infoWindow: popup,
          extent: new Extent({
            xmax: -13178092.546668783, xmin: -13180901.607458338,
            ymax: 4038066.907666304,  ymin: 4036294.524072895,
            "spatialReference":{"wkid":102100,"latestWkid":3857}
        map.on("load", loadTable);
        function loadTable(){
          // create a popup template for Bevery Hills
          // Trees by block layer
          var popupTemplate = new PopupTemplate({
            "title": "Beverly Hills Trees By Block",
            "fieldInfos": [{
              "fieldName": "Point_Count",
              "label": "Count of Points",
              "format": {
                "places": 0,
                "digitSeparator": true
              "fieldName": "relationships/0/Point_Count_COMMON",
              "label": "Sum of species tree count",
              "format": {
                "places": 0,
              "statisticType": "sum"
              "fieldName": "relationships/0/COMMON",
              "label": "Common Name"
              "fieldName": "BLOCKCE10",
              "label": "Block"
            "description": "There are {Point_Count} trees within census block {BLOCKCE10}",
            "showAttachments": false,
            "mediaInfos": [{
              "title": "Count By Type",
              "type": "columnchart",
              "caption": "",
              "value": {
                "theme": "GreySkies",
                "fields": ["relationships/0/Point_Count_COMMON"],
                "normalizeField": null,
                "tooltipField": "relationships/0/COMMON"
          var myFeatureLayer = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/Beverly%20Hills%20Trees%20By%20Blo...",{
            mode: FeatureLayer.MODE_ONDEMAND,
            infoTemplate: popupTemplate,
            outFields: ["*"],
            //set the definition expression
            definitionExpression: "TRACTCE10 = '700902'",
            visible: true,
           // apply the selection symbol for the layer
          var selectionSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.35]), 1),
            new Color([255, 0, 0, 0.35]));
          myFeatureLayer.setSelectionSymbol(selectionSymbol);
          // listen to featurelayer click event to handle selection
          // from layer to the table.
          // when user clicks on a feature on the map, the corresponding
          // record will be selected in the table.
          myFeatureLayer.on("click", function(evt) {
           var idProperty = myFeatureLayer.objectIdField;
           var feature, featureId, query;
           if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty]) {
               feature = evt.graphic,
               featureId = feature.attributes[idProperty];
               query = new Query();
               query.returnGeometry = false;
               query.objectIds = [featureId];
               query.where = "1=1";
               myFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);
          map.addLayer(myFeatureLayer);
          // create new FeatureTable and set its properties
          var myFeatureTable = new FeatureTable({
            featureLayer : myFeatureLayer,
            map : map,
            syncSelection: true,
            showRelatedRecords: true,
            showAttachments: true,
            fieldInfos: [
                alias: 'Area SQ/KM',
                editable: false,
                format: {
                  template: "${value}",
                  places: 3 // number of decimal places
                  // digitSeparator: true // default is true
            // outfields
            outFields: ["TRACTCE10", "BLOCKCE10", "GEOID", "NAME", "MTFCC", "ALAND", "AnalysisArea", "Point_Count", "Join_ID"],
          }, 'myTableNode');
          myFeatureTable.startup();
            var rFldTtile = dojoQuery(".esri-feature-table-column-header-title.esri-feature-table-related-records-title")[0].innerHTML = "Relates";
            var rFldTtile = dojoQuery(".esri-feature-table-column-header-title.esri-feature-table-attachments-title")[0].innerHTML = "Attachments";
          // listen to row-click event
          // to hide visible popups
          myFeatureTable.on("row-select", function(evt){
            if (map.infoWindow.isShowing){
              map.infoWindow.hide();
          // listen to show-attachments event
          myFeatureTable.on("show-attachments", function(evt){
            console.log("show-attachments event - ", evt);
          // listen to show-related-records event
          myFeatureTable.on("show-related-records", function(evt){
            console.log("show-related-records event - ", evt);
  </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:60%">
      <div id="map"></div>
    </div>
    <div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:40%">
      <div id="myTableNode"></div>
    </div>
  </div>
</body>
</html>
MaximSpikin1
Robert, thanks for response !
But how to turn off/on related field without setting the property "showRelatedRecords: false".
I have a few relations, some I need to turn off and some I need to turn on.
Maxim,
   Are you asking how to turn off certain fields in the related data table?
MaximSpikin1
Robert,
I have several related tables
for example, I need to turn off field Relates 0, Relates 1, Relates 4
Maxim,
  OK,
MaximSpikin1
Robert,
many thanks,
and the last question - is how to set width a columns ?
Maxim,
  That is as simple as:
myFeatureTable.grid.resizeColumnWidth(8, 60);
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
