Domain values in subtypes?
1592
5
12-13-2017 05:02 AM
MichaelGinzburg
I have a layer with subtypes and domain defined for every field in accordance with the subtype.
Same field has different domains for different subtypes.
When the layer is published to AGOL, domain values are not published but codes only.
Is there a solution?
Thanks!
DanPatterson_Retired
finding  references in the Ideas
https://community.esri.com/ideas/8826-ability-to-add-domains-and-subtypes-in-arcgis-online
don't know where you are publishing from, but read the comments to see if you fit within any of those, and the recommendations for certain conditions
XanderBakker
Esri Esteemed Contributor
Can you specify how you published the data? You should not zip a FGDB and upload it to ArcGIS Online since that will affect the domains. Publish from Pro or ArcMap directly.
MichaelGinzburg
Hello Xander,
I publish a service from Desktop.
XanderBakker
OK, so that can be removed from the list of possible causes. What version of Desktop are you using? Is it possible to share a sample of the data?
MichaelGinzburg
I use Desktop Standard 10.4.0.5524.
