ArcGIS 10 clean uninstallation
15967
6
12-11-2017 05:54 PM
GlennParaiso
Hello my dear experts,
May i know how to make a clean uninstallation of ArcGIS version 10? Upon installation of newer version, a warning always popped up that there is an older verson of ArcGIS installed. But when i go to my control panel, none of the ArcGIS instances exist.
Thanks.
Best regards,
Glenn
DanPatterson_Retired
check Stuart's post https://community.esri.com/thread/15549#comment-155352
he has 2 links there that may be of use
GlennParaiso
Thanks for the link. I tried using msi commands but nothing change. here's the error that always popped up in my screen.
Windows, Control Panel, Add Remove Programs... remove any Arc* stuff... is there a chance that just the folders were deleted and not uninstalled?  If so, then there will be a load of registry issues.  Those links were for 10... not specifically 10.2
JayantaPoddar
Maybe you could try the following.
Note: Paths may vary according to operating system. Also uninstall any third-party GIS programs that you may have installed.
Rename or delete following folders:
Rename: C:\Program Files (x86)\ArcGIS
Rename: C:\Program Files (x86)\Esri
Rename: C:\Program Files (x86)\Common Files\ArcGIS
Rename: C:\Program Files (x86)\Common Files\Esri
Rename: C:\Program Files\ArcGIS
Rename: C:\Program Files\Esri
Rename: C:\Program Files\Common Files\ArcGIS
Rename: C:\Program Files\Common Files\Esri
Rename: C:\Program Data\Esri
Rename: C:\Program Data\ArcGIS
Rename: C:\Program Data\FLEXnet
Rename: C:\Users\<USERNAME>\AppData\Local\ESRI
Rename: C:\Users\<USERNAME>\AppData\Local\ArcGIS
Rename: C:\Users\<USERNAME>\AppData\Roaming\ESRI
Rename: C:\Users\<USERNAME>\AppData\Roaming\ArcGIS
Rename: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcGIS
Rename: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Esri
Go to regedit and rename/delete the following (if they exist):
Rename/Delete HKEY_LOCAL_MACHINE\SOFTWARE\ESRI
Rename/Delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI
Rename/Delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Flex LM License Manager
Rename/Delete HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\<Delete Any Folder that contains ArcGIS or Esri>
Rename/Delete HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ArcGIS Server
Rename/Delete HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\<Delete Any Folder that contains ArcGIS or Esri within>
Rename/Delete HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\FLEXnet Licensing Service
Rename/Delete HKEY_CLASSES_ROOT\Installer\Products\<Delete Any Folder that contains ArcGIS or Esri within>
Rename/Delete HKEY_CLASSES_ROOT\Installer\Assemblies\<Delete Any Folder that contains ArcGIS or Esri within>
Rename/Delete HKEY_CLASSES_ROOT\<Delete and Folder that contains ArcGIS or Esri within>
Rename/Delete HKEY_CLASSES_ROOT\Installer\Assemblies\Global\<Delete all Keys beginning with ESRI or ArcGIS>
Reboot your system before installing the new product.
Think Location
RebeccaStrauch__GISP
What sometimes helps, especially if you had 3rd party extensions that were not deleted prior to uninstalling 10...reinstall 10, go to add/remove programs and remove the third party extensions....a reboot doesn't hurt....then use add/remove to remove ArcGIS.  This sometimes is easier than messing with the registry.
RichardDaniels
MVP Regular Contributor
Since you are at ArcGIS Desktop 10.2 you should run the 102UninstallUtility.exe that came with your software and see what you have installed. There is also a ArcGIS 10.3.1 Uninstall Utility as well that does the same thing and would allow you to remove any pre 10.3 software.
