Zoom to Extent of Feature in Dynamic Map Service
5969
17
12-06-2017 02:04 PM
deleted-user-1_r2dgYuILKY
I've found some examples of what I want to do, but none of them seem to work. I have a dynamic map service layer that is several polygon regions. When the user clicks on a region, I want the map to zoom to the extent of the region. I tried map.centerAndZoom(feature,1) and it did zoom, but the map went blank.
RobertScheitlin__GISP
Levi,
  OK here is the corrected code then:
            Layer.on("click", function(evt){
               map.setExtent(evt.graphic.geometry.getExtent(), true);
Levi,
   That is because the second parameter in the centerAndZoom method when using a esri base map would be the Level (factor is only non tiled basemaps)
https://developers.arcgis.com/javascript/3/jsapi/map-amd.html#centerandzoom
You would be better off setting the maps extent to the features extent (expanded a little).
I tried this and it didn't work. I need to find the extent of the layers within the dynamic map service.
Layer.on("click", function(){
               var layerExtent = graphicsUtils.graphicsExtent(Layer.graphics);
               map.setExtent(layerExtent, true);
What errors if any are shown in the browsers web console?
I tried this, with the evt being the click. The console logged "null."
var extent = graphicsUtils.graphicsExtent(evt.graphics);
               console.log(extent);
If I do this, the console logs the object ID:
var Id = evt.graphic.attributes["OBJECTID"]‍
console.log(Id);
Levi,
Ah, thanks!
Now I have a dynamic map service layer with multiple rasters and continental US polygons inside. I'd like to be able to zoom to each individual state when clicked. Is this possible?
You could query the map service for the extent of the clicked polygon using the map.click as the queries geometry and the QueryTask executeForExtent method.
Could I also do this inside an identify task? Right now I'm clicking on the state to get statistics in the popup.
var identifyTask, identifyParams;
       function mapReady () {
          map.on("click",executeIdentifyTask);
          //create identify tasks and setup parameters
          identifyTask = new IdentifyTask(roadsURL);
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 7;
          identifyParams.returnGeometry = true;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
          function executeIdentifyTask (event) {
            map.infoWindow.clearFeatures();
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
            identifyParams.layerIds = roadsLayer.visibleLayers;
           var deferred = identifyTask
            .execute(identifyParams);
            deferred.addCallback(function (response) {
              // response is an array of identify result objects
              // Let's return an array of features.
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                var layerName = result.layerName;
                    var iTemplate;
                    if(result.layerName === "Forecast 18 Hours"
                    || result.layerName === "Past 6 Hours"
                    || result.layerName === "Past 24 Hours"
                    || result.layerName === "Past 48 Hours"
                    || result.layerName === "Past 72 Hours"){
                    iTemplate = new InfoTemplate(layerName,"State: ${name}<br>No Snow: ${No_Snow}<br>Trace: ${Trace}<br>0.1 to 1 Inch: ${One_Inch}<br>1 to 2 Inches: ${Two_Inch}<br>2 to 6 Inches: ${Six_Inch}<br>6 to 12 Inches: ${Twelve_In}<br>12 to 18 Inches: ${Eightn}<br>Above 18 Inches: ${Above_18}"
                    feature.setInfoTemplate(iTemplate);
               return feature;
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(event.mapPoint);
            map.infoWindow.resize(225,200)
