ArcGIS JS 4.5 Change Cursor On Map Drag
4002
5
12-05-2017 02:52 PM
MalcolmGruber
I'm looking for a way to change the cursor on map drag and prevent ArcGIS from overriding it. Currently we're changing the cursor with CSS and this works for everything except for when we drag the map. ArcGIS overrides that and we're not sure where that is happening.
Tags (1)
ThomasSolow
Try setting your CSS rule on view.surface rather than view.container.
ie view.surface.style.cursor = "pointer";
RobertScheitlin__GISP
The API internally changes the cursor. I have not tested but have you tried to add a !Important on the css rule?
MalcolmGruber
We have done that, but it doesn't seem to make any difference.
Well that is what I thought.
Maybe Thomas will have an idea.
TSolow-esristaff
ThomasSolow
MalcolmGruber
That totally worked! We saw an answer similar, but setting the "data-cursor" property and that didn't work.
