Wait cursor
2239
12-03-2017 06:45 PM
MohammadrezaNikfal1
When I click om my Map View, it takes time to appear my custom popup. How can I show "Wait cursor" like default popups during this time?
ThomasSolow
The cursor is set from CSS. So setting the view container's style.cursor attribute to "wait" will do this. ie:
var el; // the element containing your map (3.X) or view (4.X)
el.style.cursor = "wait";
In the 4.X API, you should be able to get a reference to the surface element using view.surface.  From here, you can set the "data-cursor" attribute to change the cursor:
view.surface.setAttribute("data-cursor", "wait"); // set to wait
view.surface.setAttribute("data-cursor", "default"); // back to default
AlexanderRyzhov2
In  js api 4.11 (4.12) you can use undocumented "Spinner widget ".
It does the job when you use default popup widget, but it could be shown by your code too:
require([
   "esri/widgets/Spinner",
function(
  Spinner,
 ‍‍‍‍‍‍‍‍   const spinner = new Spinner({
          view: view
    view.ui.add(spinner);
    view.on("click", runIdentify);
    function runIdentify(event) {
        spinner.show({
    spinner.hide();
