Check for self-intersecting polyline
2289
11-29-2017 02:05 AM
AlexPleyer
I want to do something very simple with the ArcGIS Javascript API 3.x. Just check if a polyline is self-intersecting.
Is there anything else than getLineIntersection() or the GeometryService function Intersect() because both require me to iterate through the paths arrays and check each line part myself.
RobertScheitlin__GISP
Alex,
  Have you tried GeometryEngine.isSimple method it should return false if the polyline self-intersects.
AlexPleyer
Hi Robert,
yes I tried that, it always returns true, regardless of self-intersection or not.
Alex,
   Then, No there is no other way.
AlexPleyer
Ok thank you for your help. Doing it manually now.
