Problem on Adding Windows User to Portal
3528
5
11-27-2017 09:30 AM
MatsHardy
I have configured Portal to secure access using Windows Active Directory. I have tried to add Windows users manually to Portal by Add Members in Portal. When I chooses Add members based on existing enterprise users, Portal does not show any domain users. Anyone has ideas?
Thanks in advance.
RandallWilliams
The logs in Portaladmin should indicate if there's an issue connecting to the directory server. That's the first place I'd check.
MatsHardy
The following are the portal logs:
<Msg time="2017-11-22T16:36:01,609" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
<Msg time="2017-11-22T16:36:02,4" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
<Msg time="2017-11-23T12:38:39,295" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
<Msg time="2017-11-23T12:38:39,592" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
<Msg time="2017-11-23T12:38:40,253" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
<Msg time="2017-11-23T12:38:45,972" type="WARNING" code="219999" source="Sharing" process="4068" thread="14" methodName="" machine="xxxx" user="" elapsed=""> 在身份儲存提供者中找不到使用者 'yyyy\zzzz'。[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ]</Msg>
It seems that the Portal cannot retrieve users from AD server.
The following are the user store and group config in portal :
  "type": "WINDOWS",
  "properties": {
    "user": "yyyy\\zzzz",
    "userPassword": "",
    "isPasswordEncrypted": "false",
    "userFullnameAttribute": "cn",
    "userEmailAttribute": "mail",
    "caseSensitive": "false"
  "type": "WINDOWS",
  "properties": {
    "userPassword": "",
RandallWilliams
Is the password actually encrypted or no? When you save the JSON for this setting, Portal should encrypt the password and set the "isPasswordEncrypted": "false" value to "true".
Cesar_AugustoRodriguez
Hi Mats Hardy
You can look the next link where describe what you should to do to configure your ArcGIS Enterprise security
Use your portal with LDAP and web-tier authentication—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise
Regards
MatsHardy
I have figured out what happened. The original domain user account used in user store configuration is without password. Then I tried another domain user account with password. Then the Portal can show domain users this time.
