base map+query buffer
1050
11-26-2017 08:54 PM
anjelinaponkerat
Hi
I add query buffer to your sample code, but the map service can not show!!.
 If I remove     map.addLayer(featureLayer);     from code the map service load ok . please help me
<!DOCTYPE html>
<html>
<head>
<title>Display Multiple ArcGIS Online Services</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
<style>
html,
body {
height: 97%;
width: 98%;
margin: 1%;
#map {
border: solid 1px #B5BCC7;
padding: 0;
#paneHeader {
background: url(images/header.png) repeat-x;
color: white;
border-bottom: solid 1px #B5BCC7;
text-align: center;
height: 30px;
margin: 0;
overflow: hidden;
font-size: 16px;
padding: 8px 5px;
#rightPane {
width: 150px;
margin: 0;
padding: 0;
</style>
<script src="https://js.arcgis.com/3.22/"></script>
<script>
var map;
require([
"dojo/dom", "esri/Color", "dojo/keys", "dojo/parser", "esri/config",
"esri/sniff", "esri/map", "esri/SnappingManager", "esri/dijit/Measurement",
"esri/layers/FeatureLayer", "esri/renderers/SimpleRenderer", "esri/tasks/GeometryService",
"esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
"esri/dijit/Scalebar",
"esri/dijit/BasemapGallery",
"esri/dijit/BasemapLayer",
"esri/dijit/Basemap",
"esri/dijit/OverviewMap",
"esri/tasks/locator",
"esri/dijit/Search",
"esri/symbols/PictureMarkerSymbol",
"esri/InfoTemplate",
"esri/dijit/HomeButton",
"esri/geometry/Extent",
"esri/SpatialReference",
"esri/dijit/VisibleScaleRangeSlider",
"esri/geometry/scaleUtils",
"esri/virtualearth/VETiledLayer",
"dijit/form/Button",
"esri/tasks/query",
"esri/geometry/Circle",
"esri/graphic",
"esri/symbols/SimpleMarkerSymbol",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dijit/form/CheckBox",
"dojo/domReady!"
], function(
dom, Color, keys, parser, esriConfig,
has, Map,SnappingManager, Measurement,
FeatureLayer, SimpleRenderer, GeometryService,
SimpleLineSymbol, SimpleFillSymbol,
Scalebar, BasemapGallery, BasemapLayer, Basemap, OverviewMap, Locator, Search, PictureMarkerSymbol, InfoTemplate , HomeButton , Extent, SpatialReference, VisibleScaleRangeSlider, scaleUtils, VETiledLayer, Button, Query, Circle, Graphic, SimpleMarkerSymbol
parser.parse();
map = new Map("map");
var basemaps = [];
var waterTemplateLayer = new BasemapLayer({
url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/WaterTemplate/LocalGovernmentInfrastruct..."
var waterBasemap = new Basemap({
layers: [waterTemplateLayer],
title: "Water Template",
thumbnailUrl: "images/waterThumb.png"
basemaps.push(waterBasemap);
var publicSafetyLayer = new BasemapLayer({
url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServ..."
var publicSafetyBasemap = new Basemap({
layers: [publicSafetyLayer],
title: "Public Safety",
thumbnailUrl: "images/safetyThumb.png"
basemaps.push(publicSafetyBasemap);
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: false,
basemaps: basemaps,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(error) {
console.log(error);
esriConfig.defaults.io.proxyUrl = "/proxy/";
// Add the census block points in on demand mode. An outfield is specified since it is used when calculating the total population falling within the one mile radius.
var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",{
outFields: ["POP2000"]
// Selection symbol used to draw the selected census block points within the buffer polygon
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
12,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_NULL,
new Color([247, 34, 101, 0.9]),
new Color([207, 34, 171, 0.5])
featureLayer.setSelectionSymbol(symbol);
// Make unselected features invisible
var nullSymbol = new SimpleMarkerSymbol().setSize(0);
featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
var circleSymb = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_NULL,
SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
new Color([105, 105, 105]),
), new Color([255, 255, 0, 0.25])
var circle;
// When the map is clicked create a buffer around the click point of the specified distance
map.on("click", function(evt){
circle = new Circle({
center: evt.mapPoint,
geodesic: true,
radius: 1,
radiusUnit: "esriMiles"
map.graphics.clear();
var graphic = new Graphic(circle, circleSymb);
map.graphics.add(graphic);
var query = new Query();
query.geometry = circle.getExtent();
// Use a fast bounding box query. It will only go to the server if bounding box is outside of the visible map.
featureLayer.queryFeatures(query, selectInBuffer);
function selectInBuffer(response){
var feature;
var features = response.features;
var inBuffer = [];
// Filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
for (var i = 0; i < features.length; i++) {
feature = features;
if(circle.contains(feature.geometry)){
inBuffer.push(feature.attributes[featureLayer.objectIdField]);
query.objectIds = inBuffer;
// Use an objectIds selection query (should not need to go to the server)
featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
var totalPopulation = sumPopulation(results);
var r = "";
r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
dom.byId("messages").innerHTML = r;
function sumPopulation(features) {
var popTotal = 0;
for (var x = 0; x < features.length; x++) {
popTotal = popTotal + features.attributes["POP2000"];
return popTotal;
</script>
</head>
<body class="claro">
<span id="messages">Click on the map to select census block points within 1 mile.</span>
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width:100%;height:100%;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'" id="rightPane">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
<div id="paneHeader" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
<span>Select Basemap</span>
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
<div id="basemapGallery"></div>
</div>
</div>
</div>
</div>
</body>
</html>
RobertScheitlin__GISP
Anjelina,
   Your issue is adding the FeatureLayer is occurring before the basemap gallery widget is done so the first layer the feature layer is setting the maps WKID and thus the basemaps WKIDs do not match the maps and you get your issue. Here is your code fixed:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #map {
      padding: 0;
    #paneHeader {
      color: white;
      text-align: center;
      height: 30px;
      margin: 0;
      overflow: hidden;
      font-size: 16px;
      padding: 8px 5px;
    #rightPane {
      width: 150px;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require([
      "esri/tasks/query",
      "esri/graphic",
      "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      has, Map, SnappingManager, Measurement,
      Scalebar, BasemapGallery, BasemapLayer, Basemap, OverviewMap, Locator, Search, PictureMarkerSymbol, InfoTemplate, HomeButton, Extent, SpatialReference, VisibleScaleRangeSlider, scaleUtils, VETiledLayer, Button, Query, Circle, Graphic,
      SimpleMarkerSymbol
      parser.parse();
      var basemaps = [];
        basemaps: basemaps,
        map: map
        console.log(error);
      map.on("load", function() {
        var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0", {
          12,
        var circle;
        map.on("click", function(evt) {
            geodesic: true,
            radius: 1,
        function selectInBuffer(response) {
          var feature;
          var inBuffer = [];
            feature = features[i];
            if (circle.contains(feature.geometry)) {
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results) {
            var r = "";
          var popTotal = 0;
            popTotal = popTotal + features[x].attributes["POP2000"];
          return popTotal;
  </script>
</head>
    </div>
        </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Anjelina,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #map {
      padding: 0;
    #paneHeader {
      color: white;
      text-align: center;
      height: 30px;
      margin: 0;
      overflow: hidden;
      font-size: 16px;
      padding: 8px 5px;
    #rightPane {
      width: 150px;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require([
      "esri/tasks/query",
      "esri/graphic",
      "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      SimpleMarkerSymbol
      parser.parse();
      var basemaps = [];
        basemaps: basemaps,
        map: map
        console.log(error);
          12,
        var circle;
            geodesic: true,
            radius: 1,
          var feature;
          var inBuffer = [];
            var r = "";
          var popTotal = 0;
          return popTotal;
  </script>
</head>
    </div>
        </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
anjelinaponkerat
Hi
thanks a lot
I have one more important problem, when I use query buffer in my code, I can not use measurement tools. because when I click for measurement, it return buffer!  how can I add button for query buffer in js api like measurement tools, after select button each click start a query for buffer.
Regards
