What is the best way to update layer symbology using ArcGIS API for Python?
5362
8
11-23-2017 12:00 PM
deleted-user-qPVBo_SO6NvL
#symbology #api for python‌
What is the best way to update the symbology of a feature layer hosted on ArcGIS Online using the ArcGIS API for python?
by Anonymous User
Not applicable
Does the method demonstrated here work for you?: Service definitions | ArcGIS for Developers
For example:
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
gis = GIS('https://www.arcgis.com', 'username', 'password')
search_result = gis.content.search(query='title:test', item_type='Feature Layer Collection')
flc=FeatureLayerCollection.fromitem(search_result[0])
flc.manager.update_definition({"maxRecordCount":500})
layer = flc.layers[0]
layer.manager.update_definition({"maxRecordCount":500})
# Check the results:
print("Service max record count: {}".format(flc.properties.maxRecordCount))
print("Layer max record count: {}".format(flc.layers[0].properties.maxRecordCount))
DanPatterson_Retired
You indicate the 'best', .... does that mean you are using a method documented here.... that you want to compare to? or are you looking for something specific?
I'm following this tutorial but it is not working for me. This is what I'm doing
from arcgis import GIS
search_result = gis.content.search('test', item_type='Feature Layer Collection')
layer_collection=search_result[0]
layer = layer_collection[0]
layer.properties.maxRecordCount = 500
layer_collection.update()
The update returns True, however the maxRecordCount value is not updated in ArcGIS Online.  After supposedly updating the value printed is the layer's original maxRecordCount and not 500.
print(layer.properties.maxRecordCount)
The same thing happens when I try to update the drawing_info. I used maxRecordCount as an example for simplicity.
by Anonymous User
Not applicable
For example:
MatthewWalker
I am trying to update the feature layer collection (change syncEnabled to True, add or remove editing capabilities) and have the same code as above, but get a runtime error: "Error performing update definition operation (error code: 500)" and cannot change the properties.  I've also attempted to send a post request to change the Feature Service properties, but that does not change the properties either (no error is thrown, and printing out the post response does not seem to be an error either).  My code, after publishing the Feature Service is:
#configure Feature Layer properties
gis = GIS(PORTAL_URL, USERNAME, PASSWORD)
search_result = gis.content.search(service_name, 'Feature Layer')
fl_item = search_result[0]
fl_flc = FeatureLayerCollection.fromitem(fl_item)
update_dict = {"capabilities": "Query", "syncEnabled": True}
print(fl_flc.properties)  # you can see the properties targeted to be changed listed, they just do not get changed
fl_flc.manager.update_definition({"syncEndabled": True})#update_dict)  # this throws the 500 error
# trying this a different way--post changes directly
import requests
URL = PORTAL_URL
r = requests.post(URL, update_dict)
print(r.text)  # this prints the return html listed below
commented out code's print statement displays:
HTML Request:
<!DOCTYPE html>
<html>
<head>
<script src="login/config/dojo.js"></script>
<script src="jsapi/dojo/dojo.js"></script>
<script>
require(["login", "dojo/domReady!"], function(login) {
login.run();
</script>
</head>
<body>
</body>
</html>
I am ultimately trying to automate the publishing of feature classes to Feature Services then bundle several Feature Services into a shared web map (must be automated as the underlying feature classes can vary from map to map, and there are hundreds of map needed to be shared).
That did the trick. Thanks a lot. I hadn't found the update_definition method inside the manager classes.
StephenRoss
Could you also use this method to update the drawing info, such as the transparency of the layer?
by Anonymous User
Not applicable
It's been a while since this was asked, but here's what I've been doing in a sample of my own and it seems to work well:
gis = GIS(profile="arcgis_online")
# Upload shapefile as zip archive, and publish new layer:
shp = arcgis_enterprise.content.add({type: "Shapefile"}, r'D:\Path\To\Shapefile.zip')
new_layer = shp.publish()
# Update symbology of layer from an existing item used as a template:
template_layer = gis.content.get("a86e128a1a5b472ca926be0ead7e0b10").layers[0]
flc = FeatureLayerCollection.fromitem(new_layer)
flc.layers[0].manager.update_definition({"drawingInfo": template_layer.properties['drawingInfo']})‍‍‍‍‍‍‍‍‍‍‍‍‍
The drawingInfo property is a dictionary object that you can update as you see fit...though if you already have a layer with a matching schema that is published with a style you want to re-use, you can get it's drawingInfo property, and apply it to another layer.
MaximeCampeau
The transparency of the layer ('opacity') can be edited upon creation of the feature layer via the add_layer function called over a WebMap just like so :
item_to_search = 'City_limits_' + str(municipality)
owner = 'XXXXXXXX'
item = gis.content.search(query="title:" + item_to_search + " AND owner: " + owner, item_type="Feature Layer", sort_field='title', sort_order='asc')
print(item)
item_selected = item[0]
empty_webmap.add_layer(item_selected, options={'title':'City limits','opacity':'0.4'})
Hope this helps,
M.C.
