Python Add-In digital signature not valid
1974
11-20-2017 10:23 PM
EllisSymons
I'm trying to add a digital signature to my python add-in. I'm using ArcDesktop 10.3, and the ESRISignAddIn.exe utility from the 'Python Add-In Wizard' download. After running the exe from the ArcDesktop bin folder i get the message that 'The add-in was signed successfully', however when I double-click the .esriaddin, the dialog gives the following warning 'WARNING: This Add-In file contains invalid digital signatures.'. The 'Source is trusted' check box is checked, but the 'Signature is valid' check box is not checked.
This is occurring immediately after I have run the utility so the file hasn't been modified.
Does anyone know what the issue is?
Thanks for your help!
LuisBarreiro
This problem seems to still happen in ArcMap 10.4. I am trying to sign an add-in using the ESRISignAddin.exe utility, everything executes ok whn signing, but when installing the addin, a message saying 'invalid digital signature' appears in the installation utility. Any idea of what is the problem?
