Filter layers in Web Map with a URL parameter
6249
9
11-18-2017 11:17 PM
SimonJackson
  • I have a polygon regions layer.
  • I have a number of other layers that have already been pre-clipped to these regions
    • The region ID is included for every feature
Bit like this, the boxes are the regions:
End goal:
As a user, I want to choose a region from a dropdown, and then this opens a web map/web app with only the relevant features being shown and centered into the relevant bounding box for that region.
The bit I am struggling to work out, is a good approach to do the bit in red above.  Everything else is ok.
Some ideas:
  • I could automate creating a series of web maps with relevant filters applied to each of the layers, and then I could use the relevant Web Map ID in a URL parameters.
    • I don't like this, as will end up with lots of web maps and will be tricker if I need to update a popup/style for all of them.
  • I was hoping that I could apply a filter to all of the layers in my web map purely through using a URL parameter.  I do not think this is possible?
  • AppBuilder might be a bit of a heavy app for this, but even with a hidden filter widget, I do not think I can use a URL parameter to call an app to filter all layers with a def query.
  • If I was to go down the JS API route, it looks like I could possibly achieve what I want with featureLayer.setDefinitionExpression="regionID"
Just looking to brainstorm any ideas or send me some relevant links so I can do some homework before going down the wrong path.  Thanks!
TimConfare
This is exactly what I have been looking for as well.  With my research I have not found a solution other than creating individual web maps that you stated above.  Hopefully someone will respond with a solution.
Bud
Legendary Contributor
Bud
gyetman
Is this now possible? I see a comment "implemented" but I can't find documentation on how to feature to a subset of features based on a query (e.g., someValue < 50).
gyetman
I found the documentation, the where clause does support filtering.
nickkeller
link to documentation?
SimonAllard2
Can you please send us the link to the documentation. Cheers, Simon
SimonAllard2
Anyone have the link to the documentation?
RichardvBailey
Any luck with the link to the URL filter or where clause documentation?
