MapImageLayer Sublayer Geomtery Type
1081
5
11-17-2017 08:26 AM
RodrigoFelga
Whats is the way (if exists) to get the geometry type (point, line, polygon) of a MapImageLayerSublayer? I'm using js API 4.5. The way i'm doing is going on the server again and geting  the json of the layer to get the geometry type
RobertScheitlin__GISP
OK, from you post I was not sure if you were aware of the REST Layers endpoint for getting all map service layers or if you were doing a server round trip for each layer. As I mentioned there is not current way to do this without a service trip.
Rodrigo,
   I am not aware of any property to do this in 4.5 but you can just take the url of the whole MapService and append "layers" to the end of the url and do an esriRequest and parse the results json for layers.geometryType.
Here is a sample:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>MapImageLayer - set renderers on sublayers - 4.4</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <script src="https://js.arcgis.com/4.4/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/MapImageLayer",
        "esri/renderers/SimpleRenderer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/request",
        "dojo/domReady!"
      function(
        Map, MapView, MapImageLayer, SimpleRenderer,
        SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, esriRequest
         * Create renderers for each sublayer: cities, highways, states
        var citiesRenderer = new SimpleRenderer({
          symbol: new SimpleMarkerSymbol({
            color: "white",
            style: "circle",
            outline: {
              width: 0.5,
              color: "gray"
          label: "Cities"
        var statesRenderer = new SimpleRenderer({
          symbol: new SimpleFillSymbol({
            style: "none",
            outline: {
              width: 0.5,
              color: "gray"
          label: "State boundaries"
        var highwaysRenderer = new SimpleRenderer({
          symbol: new SimpleLineSymbol({
            style: "none",
            width: 0.7,
            color: "white"
          label: "Interstate highway"
         * Create a MapImageLayer instance pointing to a Map Service
         * containing data about US Cities, States and Highways.
         * Define sublayers with visibility for each layer in Map Service.
        esriRequest("https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/layers?f=json", {
          responseType: "json"
        }).then(function(response){
          response.data.layers.forEach(function(layer){
            console.info(layer.name + ": " + layer.geometryType);
        var layer = new MapImageLayer({
          url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer",
          sublayers: [
            renderer: statesRenderer,
            opacity: 0.4
            renderer: highwaysRenderer,
            opacity: 0.8
            renderer: citiesRenderer,
            opacity: 0.6
         * Add the layer to a map
        var map = new Map({
          basemap: "dark-gray",
          layers: [layer]
        var view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 6,
          center: [-83.114, 36.921]
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Rodrigo,
   Did the sample I posted help?
RodrigoFelga
I was already doing it that way, I'm wondering if is possible do do that without another roundtrip to the server. Thank you for your reply
GaryLSheppardJr
Is this still true in 2024? You have to manually request the URL and parse it, even if you already have a MapImageLayer object?
