base map
4032
14
11-16-2017 10:10 AM
anjelinaponkerat
Hi
I,m going to add 4  arcgis web services(tiled), as a base map by toggle tools. but I can not do this. plese help me.
Regards
anjelinaponkerat
Tiled map service, arcgis 10.2.2
RobertScheitlin__GISP
Anjelina,
  The BaseMap Toggle dijit is intended for 2 basemaps. For 4 basemaps you need to use the BaseMap Gallery dijit.
anjelinaponkerat
Hi
Do you have any sample code?
Regards
Anjelina,
  Sure see this sample:
Basemap gallery | ArcGIS API for JavaScript 3.22
anjelinaponkerat
I used this sample, but I dont know how to add my tiled web services instead of topo, satellite and other.... . I dont like esri basemap and open street, I,m going to use my own services that are from ArcGIS Server 10.2.2. please help me more.
Regards
Anjelina,
  Here is a sample for custom basemaps and using the Basemap Gallery dijit: (attached is the images that this sample requires)
<!DOCTYPE html>
<html>
<head>
  <title>Display Multiple ArcGIS Online Services</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
  <style>
    html,
    body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #map {
      border: solid 1px #B5BCC7;
      padding: 0;
    #paneHeader {
      background: url(images/header.png) repeat-x;
      color: white;
      border-bottom: solid 1px #B5BCC7;
      text-align: center;
      height: 30px;
      margin: 0;
      overflow: hidden;
      font-size: 16px;
      padding: 8px 5px;
    #rightPane {
      width: 150px;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.22/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/dijit/BasemapGallery",
      "dojo/parser", "esri/dijit/BasemapLayer", "esri/dijit/Basemap",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery,
      parser, BasemapLayer, Basemap
      parser.parse();
      map = new Map("map");
      var basemaps = [];
      var waterTemplateLayer = new BasemapLayer({
        url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/WaterTemplate/LocalGovernmentInfrastruct..."
      var waterBasemap = new Basemap({
        layers: [waterTemplateLayer],
        title: "Water Template",
        thumbnailUrl: "images/waterThumb.png"
      basemaps.push(waterBasemap);
      var publicSafetyLayer = new BasemapLayer({
        url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServ..."
      var publicSafetyBasemap = new Basemap({
        layers: [publicSafetyLayer],
        title: "Public Safety",
        thumbnailUrl: "images/safetyThumb.png"
      basemaps.push(publicSafetyBasemap);
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: false,
        basemaps: basemaps,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(error) {
        console.log(error);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width:100%;height:100%;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
    </div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'" id="rightPane">
      <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
        <div id="paneHeader" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
          <span>Select Basemap</span>
        </div>
        <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
          <div id="basemapGallery"></div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
anjelinaponkerat
Hi
This sample can not load secured web services!!! What changes I have to apply in your code?
Regards
Anjelina,
   What do you mean exactly that you cannot load secured web service? Secured web service should work in the code without any changes, assuming that the user has appropriate permissions to the service when they are prompted to login.
anjelinaponkerat
Yes, I can not load secured web services and the page has not login page!!!
If I add token after web service in my code the service load ok, if not dont load!!
What type of service are you attempting to add? When I add a secured map service I have no problem with the Identity manger login dialog to appear automatically.
