Is there a way to batch open hyperlinked pdfs?
957
11-14-2017 04:19 AM
JamieNeils
I have a point feature class in a personal geodatabase.  I would like to select a group of points and open all the hyperlinked pdf documents in the group, or even export all the hyperlinked pdfs somewhere.  Any ideas?
Tags (1)
XanderBakker
Esri Esteemed Contributor
You can create a list of the URL's and then use the code below to download them:
def main():
    import os
    folder = r'C:\GeoNet\DownloadPDFs'
    # loop through selected hyperlinks and create the list of PDF urls
    lst = ['http://www.esri.com/training/assets/downloads/esri-course-catalog.pdf',
           'http://www.esri.com/library/brochures/pdfs/arcgis-desktop.pdf',
           'http://www.esri.com/library/brochures/pdfs/arcgisextbro.pdf',
           'http://www.esri.com/library/brochures/pdfs/arcgis-for-mobile.pdf',
           'http://www.esri.com/library/brochures/pdfs/arcgis-online.pdf']
    # process pdfs
    for pdf_url in lst:
        pdf_out = os.path.join(folder, os.path.split(pdf_url)[1])
        print(pdf_out)
        download_file(pdf_url, pdf_out)
def download_file(download_url, output_pdf):
    # https://stackoverflow.com/questions/24844729/download-pdf-using-urllib
    response = urllib2.urlopen(download_url)
    file = open(output_pdf, 'wb')
    file.write(response.read())
    file.close()
if __name__ == '__main__':
    main()
