Print Template Error Message
1478
11-09-2017 12:02 PM
HayleyRobins
We have a survey form that we are using for recoding electrical testing out in the field, using the survey form on devices it all seems to be working fine.
However, we are wanting to use a template to run prints of the data from in a standardized form but doing this returns the following error message (Image attached below)
An error occurred when printing selected record
The tag beginning with "}${field12" is unopened
We've been through the template and have no field 12 that's linking to anything and in the survey excel form field 12 is an end group type. We have re published the survey several times but this hasn't resolved it.
Has anyone experienced this before or is able to offer some advice?
Many Thanks
JamesTedrick
Esri Esteemed Contributor
Hi Hayley,
Can you provide a copy of the docx template?  It looks like there's a formatting issue with a curly brace ( { or } ).
James
