Feature count
12720
14
11-07-2017 10:22 PM
eyadghatasheh
Hi
I have a file geodatabase which have around 23 datasets. under each data set there are a huge number of feature classes. I need to count features inside those feature classes.
is there any automated way to do this? get count tool is a headache in my case.
Regards
Tags (1)
shan_sarkar
Eyad,
Try using Get Count—Data Management toolbox | ArcGIS Desktop
I hope this helps!
~Shan
~Shan
eyadghatasheh
Shantona
Get count is not helpful in this case as I have batch it and drag hundreds of layers in the wizard. I am doing this daily and its not helpful anymore.
eyad.
MitchHolley1
You can use Python for this. I am going to tag Python here for visibility.  I've manipulated a code snippet found on StackExchange here to solve your problem.  The below code should do the job.
import arcpy
import os
db = r'path_to_database'
arcpy.env.workspace = db
for ds in arcpy.ListDatasets():
    for fc in arcpy.ListFeatureClasses('','',ds):
        fc_path = os.path.join(db, fc)
        fc_count = arcpy.GetCount_management(fc_path)
        print "{0} : {1} rows".format(fc, fc_count)
eyadghatasheh
Mitch
you are amazing. can I do the same to count features of feature classess in a specific dataset???
JayantaPoddar
You can just add the Dataset Name inside arcpy.ListDatasets() function.
e.g. Following would be Line No. 8 in Mitch's code
for ds in arcpy.ListDatasets('Dataset1'):
Think Location
eyadghatasheh
Jayanta
I ran the script which worked fine; but it doesn't follow the same sequence of FCs in the dataset as shown in the attached image. is there any way to get them in the same sequence and is there a way to export the result to excel?
Get count result doesn
Regards
MitchHolley1
I use the Python Excel module openpyxl.  Please download this if it's not currently installed.  The below code should work if the module is installed correctly.  Please create an empty .xlsx file and set the path to the variable in line 26.
import arcpy
import os
from openpyxl import Workbook
db = r'path_to_geodatabase_.gdb'
#wb stuff
wb = Workbook()
ws = wb.active
ws['A1'] = 'FeatureClass'
ws['B1'] = 'Count'
count = 2
    for fc in sorted(arcpy.ListFeatureClasses('','',ds)):
        fc_count = str(arcpy.GetCount_management(fc_path))
        ws['A{0}'.format(count)] = fc
        ws['B{0}'.format(count)] = fc_count
        count += 1
output = 'path_to_output_Excel_.xlsx'
wb.save(output)
DanPatterson_Retired
Instead of using the print line... why not add the results to a list, collect all the information, then sort the list at the end.
Add this to Mitch's code
result = []  # Mitch's line 7 ie the blank line
# replace this
# with
result.append("{0} : {1} rows\n".format(fc, fc_count))
#  And at the very end add this line
result.sort()
result_txt = "\n".join([i for i in result])
print(result_txt)
JoshuaBixby
MVP Esteemed Contributor
The ArcPy Data Access Walk function was created for such a situation:
fgdb = # path of file geodatabase
for root, fds, fcs in arcpy.da.Walk(fgdb, datatype="FeatureClass"):
    for fc in fcs:
        fc = os.path.join(root, fc)
        print fc[len(fgdb)+1:], arcpy.GetCount_management(fc)
