Custom Report - Repeat Data Not Working
2362
6
11-01-2017 05:26 PM
DonShort
I'm working on my first Custom Print report for Survey123.   My survey was created using Survey123 Connect.   In my XLS form, I have a few groups.   Each group has a repeat inside it.  None of the groups or repeats are nested.
The default Print function properly shows data repeated within each group, but I cannot get it to work on my custom report.
Here's a screenshot of the XLS form definition:
Here's a screenshot of the Schema Preview in Connect:
Here's a screenshot of the repeat defined in my report template:
I've been banging my head on this seemingly simple issue for a bit.
What am I missing?
I've tried defining the image size, adding and removing the ${crewmember_name} field from the repeat (removed in screenshot above) and just about anything else I can think of.
JamesTedrick
Esri Esteemed Contributor
Hi Donald,
There's currently a limitation with the print functionality - it will not process repeats that are inside a group.  This will be addressed at the 2.5 release of Survey123.
BradFuqua
Thanks for the reply James.   Is there a date scheduled for the release of v2.5?
JamesTedrick
We're currently going through final testing; we anticipate being able to release either next week or the week after.
JevitaWebster
Hello James,
im currently working on a custom report that the repeats are inside a group. Is there documentation on that now?
JamesTedrick
Hi Jevita,
The group is ignored by the feature report generation - you need to specify the repeat as documented at Print survey results—Survey123 for ArcGIS | ArcGIS
MichelleTanner
Hello I seem to be running into this issue as well. has the group/repeat functionality been fixed for this latest release of survey123?
