Alexander,
I would absolutely be a issue with unintended use. Here is how it should be done:
<html>
<head>
<meta name="viewport" content="width=device-width,user-scalable=no">
<title>Maps Toolbar</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/nihilo/nihilo.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
<style>
html,
body,
#mainWindow {
font-family: sans-serif;
height: 100%;
width: 100%;
html,
body {
margin: 0;
padding: 0;
#header {
height: 80px;
overflow: auto;
padding: 0.5em;
</style>
<script src="https://js.arcgis.com/3.22/"></script>
<script>
var map, symbol, mapClickEvt;
require([
"esri/map",
"esri/toolbars/draw",
"esri/graphic",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"dojo/parser", "dijit/registry",
"dojo/on",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dijit/form/Button", "dijit/WidgetSet", "dojo/domReady!"
], function(
Map, Draw, Graphic,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
parser, registry, on
parser.parse();
map = new Map("map", {
basemap: "streets",
center: [-15.469, 36.428],
zoom: 3
map.on("load", createToolbar);
function createToolbar(themap) {
polylineToolbar = new Draw(map);
polylineToolbar.on("draw-end", addToMap);
on(dojo.byId('draw'), 'click', activateTool);
function activateTool() {
mapClickEvt = map.on("click", function(evt){
symbol = new SimpleMarkerSymbol();
var graphic = new Graphic(evt.mapPoint, symbol);
map.graphics.add(graphic);
polylineToolbar.activate(Draw["POLYLINE"]);
function addToMap(evt) {
if(mapClickEvt){
mapClickEvt.remove();
var symbol;
polylineToolbar.deactivate();
switch (evt.geometry.type) {
case "point":
case "multipoint":
break;
case "polyline":
symbol = new SimpleLineSymbol();
break;
default:
symbol = new SimpleFillSymbol();
break;
var graphic = new Graphic(evt.geometry, symbol);
</script>
</head>
<body class="nihilo">
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'">
<div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
<span>Draw:<br /></span>
<button data-dojo-type="dijit/form/Button" id="draw">Point and Polyline</button>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
