OpenWeatherMap and WebTiledLayer, issue with tile download
3789
10-28-2017 08:14 PM
NachiChidambaram
I am trying to integrate OpenWeatherMap weather layers into esri map. So that I can see some real time weather data on the map.
When I create a weather layer using WebTiledLayer , it creates the layer and adds it to the map just fine no errors in console, but it doesn't display anything except basemap.  When I watch the network traffic, it looks like 1 request is made to OpenWeatherMap layer and then no request are made for that layer.  If  I zoom or pan, I can see the basemap requests are made and redrawn, but nothing for my OpenWeatherMap- WebTiledLayer. Am I missing something very basic here ?
I am following the code sample from : WebTileLayer | ArcGIS API for JavaScript 4.5
Here is my code :
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>WebTileLayer - 4.5</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
<script src="https://js.arcgis.com/4.5/"></script>
<script>
var tiledLayer;
require([
"esri/config",
"esri/layers/WebTileLayer",
"esri/Map",
"esri/views/MapView",
"dojo/dom",
"dojo/domReady!"
], function(esriConfig, WebTileLayer, Map, MapView, dom) {
esriConfig.request.corsEnabledServers
.push("http://tile.openweathermap.org/");
var map = new Map({
basemap: "dark-gray"
var view = new MapView({
container: "viewDiv",
map: map
tiledLayer = new WebTileLayer({
urlTemplate: "http://tile.openweathermap.org/map/pressure_new/{z}/{x}/{y}.png?appid={my_app_id}"
map.add(tiledLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Nachi,
  1. You will have to manually add a legend.
  2. The layer will only be updated when it is redrawn by panning the map or zooming.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Here is the code for adding the legend:
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .leaflet-control-color-scale {
      font-family: Source Sans Pro, sans-serif;
      font-size: 10px;
      background: #fff;
      color: #777;
      box-shadow: 0 1px 2px 1px rgba(0, 0, 0, .5);
      border-radius: 5px;
      padding: 0;
      height: 26px
    .leaflet-control-color-scale-line {
      margin: 15px 5px 5px;
      position: inherit;
      height: 5px;
      border-top: 1px solid #777;
      border-bottom: 1px solid #777
    .scale-value {
      position: absolute;
      display: inline;
      bottom: 0;
      height: 16px;
      vertical-align: top
    .scale-value span {
      line-height: 100%;
      vertical-align: top
    .scale-value:not(:last-of-type) {
      border-left: 1px solid #777
    .scale-value:last-of-type {
      border-right: 1px solid #777
    .scale-min-value {
      left: 0
    .scale-max-value {
      right: 0
    .leaflet-control {
      position: relative;
      z-index: 7;
      pointer-events: auto
    .leaflet-control {
      float: left;
      clear: both
    .leaflet-right .leaflet-control {
      float: right
    .leaflet-bottom .leaflet-control {
      margin-bottom: 10px
      margin-right: 10px
  </style>
  <link rel="stylesheet" href="http://js.arcgis.com/4.5/esri/css/main.css">
  <script src="http://js.arcgis.com/4.5/"></script>
  <script>
    var tiledLayer;
    require([
      "esri/config",
      "esri/Map",
      "dojo/dom",
      "dojo/domReady!"
        .push("a.tile.openweathermap.org", "b.tile.openweathermap.org", "c.tile.openweathermap.org", "d.tile.openweathermap.org");
      var map = new Map({
        map: map
        urlTemplate: "http://{subDomain}.tile.openweathermap.org/map/pressure_new/{level}/{col}/{row}.png?appid=9f5433f1cefe46298484a3cba3f6d095",
        subDomains: ["a", "b", "c", "d"]
  </script>
</head>
<body>
  <div id="viewDiv">
    <div class="leaflet-bottom leaflet-right">
      <div class="leaflet-control-color-scale leaflet-control" style="display: block; background: none; box-shadow: none; border-width: 0px;">
        <div class="leaflet-control-color-scale-line" style="width: 300px; background-image: none; position: relative; bottom: 65px; right: -15px; border-width: 0px;">
          <div class="leaflet-control-color-scale leaflet-control" style="display: block; width: 360px;">
            <div class="scale-value" style="margin-left: 10px;border:0"><span>Temp</span></div>
            <div class="leaflet-control-color-scale-line" style="background-image: linear-gradient(to right, rgb(159, 85, 181) 0%, rgb(44, 106, 187) 8.75%, rgb(82, 139, 213) 12.5%, rgb(103, 163, 222) 18.75%, rgb(142, 202, 240) 25%, rgb(155, 213, 244) 31.25%, rgb(172, 225, 253) 37.5%, rgb(194, 234, 255) 43.75%, rgb(255, 255, 208) 50%, rgb(254, 248, 174) 56.25%, rgb(254, 232, 146) 62.5%, rgb(254, 226, 112) 68.75%, rgb(253, 212, 97) 75%, rgb(244, 168, 94) 82.5%, rgb(244, 129, 89) 87.5%, rgb(244, 104, 89) 93.75%, rgb(244, 76, 73) 100%); width: 300px; float: right;">
              <div class="scale-value scale-min-value"><span> -40 °C </span></div>
              <div class="scale-value scale-avg-value" style="left:50%"><span> 0 °C </span></div>
              <div class="scale-value scale-max-value"><span> 40 °C </span></div>
            </div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Nachi,
  Here is the code setup properly to work:
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    var tiledLayer;
    require([
      "esri/config",
      "esri/Map",
      "dojo/dom",
      "dojo/domReady!"
        .push("a.tile.openweathermap.org","b.tile.openweathermap.org","c.tile.openweathermap.org","d.tile.openweathermap.org");
      var map = new Map({
        map: map
        urlTemplate: "http://{subDomain}.tile.openweathermap.org/map/pressure_new/{level}/{col}/{row}.png?appid=YOURAPIKEY",
  </script>
</head>
<body>
</body>
</html>
NachiChidambaram
Thank you . It works great.
Couple of related questions :
1. Do I need to do something special to display pressure map legends in esri  ?
example link :
Interactive weather maps - OpenWeatherMap
2. When OpenWeatherMap data updates , does esri map layer update automatically ?
In other words if the weather api updates every 10 mins does the esri WebTileLayer also update ? (with out any UI interaction)
Nachi,
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      font-size: 10px;
      background: #fff;
      color: #777;
      border-radius: 5px;
      padding: 0;
      height: 26px
      position: inherit;
      height: 5px;
    .scale-value {
      position: absolute;
      display: inline;
      bottom: 0;
      height: 16px;
      vertical-align: top
    .scale-value span {
      line-height: 100%;
      vertical-align: top
    .scale-min-value {
      left: 0
    .scale-max-value {
      right: 0
    .leaflet-control {
      position: relative;
      z-index: 7;
    .leaflet-control {
      float: left;
      clear: both
      float: right
      margin-bottom: 10px
      margin-right: 10px
  </style>
  <script>
    var tiledLayer;
    require([
      "esri/config",
      "esri/Map",
      "dojo/dom",
      "dojo/domReady!"
      var map = new Map({
        map: map
  </script>
</head>
<body>
  <div id="viewDiv">
            </div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
