Performance issues in python using gdb
890
10-23-2017 03:35 AM
martinschaefer1
 I've found in a couple of examples that using gdb as output in python toolboxes is much slower than standard files or shapefiles. Running in ArcPro 2.0.1
  1. Toolbox that has a function that needs arcpy.sa.sample output for further processing.
    1. output sample results to .dbf, read back into a dataframe, delete dbf - 6.5s
    2. output sample results to scratch gdb, which is cleaner, read back into df - 25s
  2. toolbox that outputs new feature classes
    1. outputs to shp - 5.19s
    2. outputs to gdb - 18.8s
In both cases the only difference in code is the storage in a gdb. Is anyone else seeing this performance issue using gdb storage?
Cheers
M.
Code snippet example for 1.1:
out_table = (os.path.join(dir, 'zzz_{}.dbf'.format(os.path.basename(in_fc)[:-4])))
Sample(in_dem, in_fc, out_table, 'NEAREST')
#read sample output into df
fields = [f.name for f in arcpy.ListFields(out_table)]
df_sample = pd.DataFrame(arcpy.da.TableToNumPyArray (
                           in_table = out_table,
                           field_names = fields,
                           skip_nulls = True
#remove sample output
for _ in os.listdir(dir):
if _.startswith('zzz_'):
   os.remove(os.path.join(dir, _))
out_table = arcpy.CreateScratchName(workspace=arcpy.env.scratchGDB)
df_sample = pd.DataFrame(arcpy.da.TableToNumPyArray(
                        skip_nulls = True
