I wrote a tool script using python that collects a couple of feature classes (from different Feature data sets in the same gdb) as several GetParameterAsText.
When I now want to start editing I figured out that it requires to address the gdb and not the Feature data set (or the feature class). But all methods I found until now refer to the feature data set.
like
os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN>_polygonfeature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
