Link to Network Server File
444
10-13-2017 07:40 AM
JeffJackson1
Is it possible to add a link to a network server file in the About widget?
RobertScheitlin__GISP
Jeff,
  Sure you can open the About widgets settings in WAB and add your hyperlink by clicking the link button in the settings dialog.
JeffJackson1
Hello Robert,
I have successfully added links using http but I need to link to a file instead.  I was able to do this in the About widget in Operation Dashboard, but linking to a file on a network server is not working in WAB.
Jeff,
  I never use actual network link files in a web app (just not good practice). You should take that network share folder and setup a virtual directory in IIS (if that is your web server) that way you have an actual url to use in you about link.
