Change datasource in .lyr files in specific folder
11084
20
10-12-2017 12:48 PM
JoseSanchez
Good afternoon everyone,
We have a folder  with 175 .lyr files. All .lyr files are pointing to an SDE instance and we need to change each lyr data source to point to another SDE instance.
I am looking for a way to do that in python where I can loop through all files in the folder and change their datasource.
JoshuaBixby
MVP Esteemed Contributor
Sharing with https://community.esri.com/community/developers/gis-developers/python?sr=search&searchId=998cdb5b-d7...‌ since this seems more an ArcPy question than ArcGIS API for Python.
MicahBabinski
Hi Jose,
As with anything arcpy related, the documentation is your friend. Being able to read through the documents and figure out how to do this kind of thing is essential to becoming a good python/arcpy scripter. Have a look at this topic and see what you can do:
Updating and fixing data sources with arcpy.mapping—Help | ArcGIS for Desktop
The generalized process I would do is:
  1. List all .lyr files using os.listdir() or arcpy.ListFiles("*.lyr")
  2. Create a top-level layer object from the layer file
  3. Loop through each sublayer, determine if it supports the data source property
  4. Update the data source
  5. Save the top-level layer object
Good luck!
JoseSanchez
Hello everyone,
I was able to browse all .lyr files, but when the script runs the line replaceDataSource, nothing happens.
# List all lyr files
lyrFileList = arcpy.ListFiles("*.lyr");
arcpy.env.workspace = newSdePath
for lyrFile in lyrFileList:
   print lyrFile
   lyr = arcpy.mapping.Layer(os.path.join(folderpathLayerFiles,lyrFile))
   if lyr.supports("DATASOURCE"😞
      print lyr.dataSource
      print lyr.datasetName
      value = "xxx.xxx." + lyr.datasetName.split(".")[1]
      if arcpy.Exists(value):
         print "Replace Datasource for " + value
         lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", "", True)
MichaelVolz
Are all the lyr files for single SDE feature classes or do you have some group lyr files?  I mention this because I created a script where I had to change the source of lyr files and I had to drill down to each individual lyr in the group lyr file when I encountered a group lyr file.
Did you validate that the newSdePath is valid and would connect to the new SDE database in ArcCatalog?
MicahBabinski
Hi Jose,
If the dataset names are the same try:
lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", lyr.datasetName, True)
or:
lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", "#", True)‍
The empty double-quotes for the dataset_name parameter could be causing your validation to fail.
Micah
JoseSanchez
Hi Michael,
Each  .lyr files points to one single feature class. And feature classes are stand alone feature classes or part of a feature dataset.
To populate newSdePath I just copy/pasted the value form ArcCatalog.
newSdePath = r"Database Connections\SQL Prod.sde"
MichaelVolz
Are you showing all the code for the script?  I ask because I don't see where you set the value of newSdePath.  I just see that arcpy.env.workspace is set to newSdePath which would be empty if you have not set that value in code.
DanPatterson_Retired
in all the examples in the listed http://desktop.arcgis.com/en/arcmap/10.3/analyze/arcpy-mapping/updatingandfixingdatasources.htm help topic, they show an *mxd being loaded, stuff being done, then a copy of the mxd being saved... I wonder...
JoseSanchez
Hi again,
below is a copy/paste of most of the code:
import arcpy
import sys, traceback, string, os
import logging
import datetime
import time
import calendar
folderpathLayerFiles =  r"\\....LayerFiles"
folderpathSymbology =  r"\\....Symbology"
arcpy.env.workspace = folderpathLayerFiles
newSdePath = r"xxxx.sde"
def CreateErrorFlag(aJobName):
    try:
        commandLine = "trap.cmd " + aJobName
        aresult = os.system(commandLine)
        if aresult > 0:
            sys.exit(1)
    except:
        return (aresult)
        print "error"
        sys.exit(1)
try:
    logging.info(':=================================== START LOGGING')
    logging.info("Start Script: " + time.strftime("%c"))
    print "Start Script: " + time.strftime("%c")
        print lyrFile
        if lyr.supports("DATASOURCE"):
            value = "xxxx.xxx." + lyr.datasetName.split(".")[1]
                #lyr.findAndReplaceWorkspacePath(find_workspace_path=lyr.workspacePath, replace_workspace_path=newSdePath)
                lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE",lyr.datasetName, True)
