Error while using "require" on esri library
1456
10-12-2017 05:47 AM
YashvitNaik
I am currently using esri version 3.14. When I try to load the map, it gives me "Cannot read property 'decimalFormat' of undefined".
Before loading the map, i have specified an array of object like so: ("esri/graphicsUtils", "esri/config") which are required to load the map. I do a require() using this array, which throws the above mentioned error and doesn't load the data.
RobertScheitlin__GISP
Can you post your code for review?
YashvitNaik
Sorry for the delayed response. Please find the code and error log below.
Following is the Code:
var dependencies = {
               graphicsUtils: "esri/graphicsUtils",
               esriConfig: "esri/config",
               Map: 'esri/map',
               Basemaps: "esri/basemaps",
               BasemapGallery: "esri/dijit/BasemapGallery",
               BasemapLayer: "esri/dijit/BasemapLayer",
               Basemap: "esri/dijit/Basemap",
               BasemapToggle: "esri/dijit/BasemapToggle",
               ArcGISDynamicMapServiceLayer: "esri/layers/ArcGISDynamicMapServiceLayer",
               ArcGISTiledMapServiceLayer: "esri/layers/ArcGISTiledMapServiceLayer",
               GeometryService: "esri/tasks/GeometryService",
               ProjectParameters: "esri/tasks/ProjectParameters",
               Navigation: "esri/toolbars/navigation",
               LengthsParameters: "esri/tasks/LengthsParameters",
               Search: "esri/dijit/Search",
               GeoCoder: "esri/dijit/Geocoder",
               identityManager: "esri/IdentityManager",
               identityManagerBase: "esri/IdentityManagerBase",
               InfoTemplate: 'esri/InfoTemplate',
               SimpleFillSymbol: 'esri/symbols/SimpleFillSymbol',
               SimpleMarkerSymbol: 'esri/symbols/SimpleMarkerSymbol',
               CartographicLineSymbol: "esri/symbols/CartographicLineSymbol",
               PictureMarkerSymbol: "esri/symbols/PictureMarkerSymbol",
               PictureFillSymbol: "esri/symbols/PictureFillSymbol",
               ScaleDependentRenderer: 'esri/renderers/ScaleDependentRenderer',
               Draw: "esri/toolbars/draw",
               Edit: "esri/toolbars/edit",
               SimpleLineSymbol: "esri/symbols/SimpleLineSymbol",
               Graphic: "esri/graphic",
               GraphicsLayer: "esri/layers/GraphicsLayer",
               Color: 'dojo/_base/Color',
               Legend: 'esri/dijit/Legend',
               //Edit Feature Layer
               FeatureLayer: 'esri/layers/FeatureLayer',
               AttributeInspector: 'esri/dijit/AttributeInspector',
               UniqueValueRenderer: 'esri/renderers/UniqueValueRenderer',
               Button: 'dijit/form/Button',
               IdentifyTask: "esri/tasks/IdentifyTask",
               IdentifyParameters: "esri/tasks/IdentifyParameters",
               Locator: "esri/tasks/locator",
               QueryTask: "esri/tasks/QueryTask",
               Query: "esri/tasks/query",
               Extent: "esri/geometry/Extent",
               FindTask: "esri/tasks/FindTask",
               FindParameters: "esri/tasks/FindParameters",
               SpatialReference: "esri/SpatialReference",
               Geometry: "esri/geometry/Geometry",
               Point: "esri/geometry/Point",
               Polygon: "esri/geometry/Polygon",
               TextSymbol: "esri/symbols/TextSymbol",
               BufferParameters: "esri/tasks/BufferParameters",
               Print: "esri/dijit/Print",
               PrintTemplate: "esri/tasks/PrintTemplate",
               esriRequest: "esri/request",
               arrayUtils: "dojo/_base/array",
               Editor: "esri/dijit/editing/Editor",
               dom: "dojo/dom",
               domReady: "dojo/domReady!",
               domConstruct: "dojo/dom-construct",
               PrintParameters: "esri/tasks/PrintParameters",
               PrintTask: "esri/tasks/PrintTask",
               Geocoder: "esri/dijit/Geocoder",
               dojo: "dojo",
               registry: "dijit/registry",
               ScreenPoint: "esri/geometry/ScreenPoint",
               TemplatePicker: "esri/dijit/editing/TemplatePicker",
               Bundle: "dojo/i18n!esri/nls/jsapi",
               Moveable: "dojo/dnd/Moveable",
               DomClass: 'dojo/dom-class',
               circle: "esri/geometry/Circle"
var reqArray = _.values(dependencies);
var keysArray = _.keys(dependencies);
require(reqArray, function () {
               var args = arguments;
               // esri code goes here
We are getting following Error cause of Require JS
NumberTextBox.js:2 Uncaught TypeError: Cannot read property 'decimalFormat' of undefined
    at k (NumberTextBox.js:2)
    at NumberTextBox.js:3
    at ha (init.js:22)
    at ha (init.js:22)
    at ha (init.js:22)
    at init.js:23
    at ia (init.js:23)
    at fa (init.js:23)
    at g (init.js:25)
    at HTMLScriptElement.<anonymous> (init.js:30)
Yashvit,
  Sorry I did not understand you were using RequireJS. I do not have any experience in using that so I will have to let someone else chime in.
YashvitNaik
Yes, That will be great.
Waiting for your response.
Thank you.
